Originally Posted by Nate Laverdure
Johnny 5 is alive!
I assume the two side-arms are to move the ringer right under the suction cups. What drops the two side-arms into position?
That one I can answer. Right next to the pneumatic tubing on the left side of the tower you should see a bracket with a piston attached to it. The piston moves the "feelers", which, as you correctly said, should (knock on wood) position the tube right where it needs to go. The feelers are welded aluminum rod (1/4", I think), and we have 2 spare sets, just in case-
EDIT: Thanks dhoizner. That "identifying mark" works too.
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
