Go to Post Having a spare arm that you can put on in 5 minutes or less intimidates the hardware into not breaking. - ChrisH [more]
Unread 28-02-2007, 19:58
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
Re: pic: MOE 2007 - MOEzilla
Originally Posted by Joohoo View Post
Sweet looking robot
424 grr used an arm simmilar to your design. We weren't able to control which arm segment went up first did you figure something out to fix that?
or did you just not encounter that problem?
Early in build we had problems with the large white slider (in the picture between gripper stage and next stage) seizing in the bosch tubing tracks. That made the stages go up unevenly. After fixing the sizing of that slider, the stages lifted smoothly and consistently.
As Ben Piecuch pointed out, this is essentially the same lifter we used 2 years ago (right down to the window motor rotation) so we had some time to tweak the design. I don't know specifics (being a control systems guy ) but I would guess:
the sliders (possibly different for different stages),
staggering of the stages,
tensioners and
double winding (one chord pulls up and the other down)
One or more of the above has something to do with it (I just basically named every part). Stop by our pit at FLR and someone much more knowledgeable than I, would be happy to talk design with you.
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
pic: MOE in Atlanta Steve Howland Extra Discussion 11 03-05-2006 17:02
pic: MOE cheering Carol Extra Discussion 1 04-04-2006 11:28
pic: EL - MOE Mr MOE Extra Discussion 3 19-09-2005 22:15
pic: MOE 365 Teaser CD47-Bot Robot Showcase 2 14-02-2004 17:24
pic: MOE stacking tubby CD47-Bot Extra Discussion 3 21-05-2003 21:44
