Go to Post hiring a monkey may not be a good idea i used that method once and it cost me a fried motherboard... - Cuog [more]
Unread 28-02-2007, 20:05
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: pic: 379's transmission
Originally Posted by 114ManualLabor View Post
0 rpm doesn't happen in a internal combustion engine, as the motor is not turning. I have a feeling they did their calculations based on the max rpm of the motor, or 5200 rpm.
Sorry, but my odd sense of sarcasm doesn't come across well online. Specs for internal combustion engines usually quote a torque and speed so that you have a better idea of what the engine is capable of. I assume that these claims are all based on calculations and are not actual. The point is that PM electric motors and internal combustion engines are very different and most of the time comparisons are not very usefull. I agree that the probably used 5200 rpm and their highest gear ratio to calculate the 15 fps. But they probably used stall torque and the lowest gear ratio to calculate torque not realizing that at stall the CIM draws 133 amps, so they will not produce 280 ft-lbs of torque for very long.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
pic: 2 Speed Transmission AustinSchuh Extra Discussion 20 30-12-2006 16:39
pic: 2 speed transmission 1 psyco_klown Extra Discussion 3 05-09-2006 19:03
pic: 2 speed transmission 2 psyco_klown Extra Discussion 0 22-05-2006 13:35
pic: 379's 2006 Robot Cat 7 Robocat1 Robot Showcase 16 05-03-2006 12:20
pic: 1141 gets under 379's skin CD47-Bot Extra Discussion 2 06-04-2004 09:27
