Originally Posted by Squishylizard
We're sort of hoping that the 72 x 72 rule isn't heavily enforced, we can put our manipulator on backwards though and run the arm on the other side of the robot.
Umm, it's a rule and yes it will be enforced, if the head ref thinks you violate the rule, they will have you checked out before sending back to the pit, if the rule is broken most likely you won't recieve any points if you won the match.
(atleast that what has happened from previous years, correct me if im wrong)
