Go to Post I thought you guys were surposed to be nerds. - Funzo [more]
Unread 01-03-2007, 21:57
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Re: pic: 2007 FRC Team 548 Robostangs Robot Pic2
Gabe came the closest... we lift up our robot completely off the ground in order to achieve low gearing, and high torque.... this is how it works.... We create 290lbs. of torque because of an all student designed drive train that instead of using a two speed transmission uses a custom working trans. like this... In high speed (Low Torque) two big diameter small width wheels on the ground and two scrubber wheels.... In low speed (High Torque) Four wheels with a smaller diameter and larger width come slamming to the ground to lift the entire robot and speed wheels off the ground to create an amazing amount of force on the opposing object (shall i say robot) we have found that if we put our 2006 bot sideways we can push it with amazing ease.
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
pic: 2007 FRC Robostangs Team 548 Robot robostangs548 Extra Discussion 1 02-03-2007 15:11
pic: 2007 FRC Team 548 Robostangs Robot Pic3 robostangs548 Extra Discussion 4 01-03-2007 21:53
pic: (Real) Robostangs Team 548 FRC 2007 Wheels & Sprockets robostangs548 Extra Discussion 6 03-02-2007 11:46
pic: Team 40 Mini FRC 2007: The Field (sans rack) Jessica Boucher Extra Discussion 2 22-01-2007 16:05
