Go to Post How well does peanut butter transmit heat? - Lil' Lavery [more]
Unread 04-03-2007, 21:48
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: pic: FRC1341's 2007 Robot Fully Deployed
Originally Posted by RoboMadi View Post
looking good!
psst.....are you guys planning to cover your electronics? Funky things can happen when another manipulator tries to dig in
We plan on doing that at the regional
Originally Posted by Arefin Bari View Post
So I see the 2006 bot in the back. Adam, fix your shoootteerrr!
Now for the 2007 robot.
1) do you have a FP motor directly attached to the shoulder for the bot?
2) How much does the whole thing weigh?
3) What are the ramps made out of?
4) Does your cam work? Planning on protecting it at all?
5) Do I have to come after you this year too saying, "Fix your ramps?" =)
1) Its actually a banebots motor attached to a 1:64 banebots gearbox attached to the second stage of the FP gearbox directly attached to the shoulder.
2) 110 (a little bit under)
3) Aluminum mesh
4) It works somewhat. We may nix it and then replace it at various times during the regional depending on the time our programmer has
5) Probably
Ramp? i thought they are using the CAT forklift; pictured in back
Imad
I wish.
pic: 696 Circuit Breakers - Wings Deployed sanddrag Robot Showcase 15 08-04-2007 15:41
pic: 1429 Ramps deployed Pjohn1959 Robot Showcase 11 15-02-2007 15:09
pic: FRC488 Lift Mechanism Deployed Madison Extra Discussion 17 03-02-2007 23:17
pic: 498's Aircraft Carrier Deployed Donut Extra Discussion 18 19-01-2007 15:03
pic: 476 - wings deployed CD47-Bot Robot Showcase 8 02-04-2003 23:37
