wow, a lot more questions then i expected.
Originally Posted by Rich Ross
I realise i might havecome off as slightly hostile in my earlier post. If anyone took offense, i'm sorry.
two quick questions:
1. How do those things deploy? any video available?
we do, but im not sure who has the video of them falling
2. Any chance at a view of the underside so that the ramp lovers out there can see your bracing?
im at school right now, but when i get home, ill get another rendering of it showing the bottom of it
Originally Posted by Lostmage333
WOW...
That's one BEAUTIFUL bot! I presume it's made to hold 2 robots 12" high....
thanks! yup
So, a few quick questions.
First: What is the angle of incline on your ramps?
not sure but in the region of 21 degrees
Second: Could you give us some specks of your drivetrain?
4 wheel drive
1 cim per wheel
pnuematic casters for easy turning
Third: It seems like you can score on all 3 levels, but how easy is it to score on them (especially the middle one, based on your rendering, unless it has one last pivot that I am not seeing, it seems that may be most difficult).
there is no pivot, but we can score on all three easily
Fourth: Which side do you pick up ringers from? (the side with the ramps or without?)
the side without
<EDIT> more questions ^.^
Fifth: Does anything protect your arm device from being hit by robots coming onto your ramps?
not much besides the supports and the driver's ability to stop their robot
Sixth: How long does it take for you to deploy your ramps?
less than 5 seconds probably about 3ish
Originally Posted by JulieB
How do yall get all the ramps to fall?
released by a pnuematic latch and then gravity and some help from surgical tubing
</EDIT>
Overall, it's one of the nicest looking bots all year, good job!
thanks
