Go to Post ...because "someone on ChiefDelphi said so," doesn't fly when your robot can't pass inspection. - Madison [more]
Unread 06-03-2007, 11:34
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: pic: 141 rendering with ramps down
Hopefully this will end up being a link to the YouTube Video of Team 141 Deploying their ramps. This was the second time we deployed, the programers had not entered the code to deploy so two students, one for each wing had to trip the pneumatic solenoids manually twice by hand. The operator control that is now programed actually deploys the wings a little bit faster. Each side can be individually deployed or they can be deployed at the same time. You are required to hold down one button and then press another to deploy, hopefully no accidental deployments! There are no supports underneath the panels. Honey combed fiberglass panels with alluminum J Channels around the outside. Extremely strong and lightweight. It is designed for a 13 inch elevation to allow for slight bending of the panels.
http://www.youtube.com/watch?v=Bt1ulluE7mk
This is a video of our 2006 Robot Climbing the Ramp
http://www.youtube.com/watch?v=FlK1vP72OCw
pic: Ramps in action. hiimcristhian Extra Discussion 2 20-02-2007 13:08
pic: Ramps in action 2. hiimcristhian Extra Discussion 3 20-02-2007 13:04
Robots with Ramps UlTiMaTeP General Forum 6 17-02-2007 19:33
Image Discuss: Team 141 WO-BOT with massive stack CD47-Bot Robot Showcase 2 21-02-2003 23:36
