Go to Post Building sustained excellence happens when you start with the right pieces at the top...and pick up the rest of the pieces on your way. - Jared Russell [more]
Unread 09-03-2007, 02:06
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Re: pic: RoboRaider-2007
Wow! nice arm guys. With three joints, how do you guys program it? One joystick axis for each joint? Or did you guys write a program to have the arm follow a set path?
Unread 09-03-2007, 08:15
John C's Avatar
John C John C is offline
FRC #0075 (RoboRaiders)
John C has a spectacular aura aboutJohn C has a spectacular aura about
It can pick up from the floor however we prefer to take tubes from over the wall because it is faster.
Unread 09-03-2007, 09:08
Rafi Ahmed's Avatar
Rafi Ahmed Rafi Ahmed is offline
Mentor & Alumni
FRC #2522 (Royal Robotics)
Rafi Ahmed has a spectacular aura aboutRafi Ahmed has a spectacular aura about
How do you control all the joints?
Team 2522 | Mentor
Formerly of Team 22 and Team 4
Unread 09-03-2007, 17:43
John C's Avatar
The bottom two joints are driven by the same motor and controlled by the Y- axis of the left joystick. The third arm segment is controlled with the Y- axis of the right joystick. The grabber open and close and the wrist motion are controlled with the buttons on each joystick. The turret is controlled by the X- axis of the right joystick. The box contains the activation for our presets which will move the arm to a previously stored position. We have 4 presets for load positions and 6 for putting tubes on the rack (2 positions for each height). The presets can be overridden at any time by moving the joysticks. It may seem complicated but it’s actually fairly easy to control. When we place tubes on the rack I usually use the preset to get close then override it to finish lining it up.
Unread 09-03-2007, 18:08
Doliver's Avatar
Doliver Doliver is offline
AKA: Douglas
FRC #1382 (Tribotec Team)
Doliver will become famous soon enough
Send a message via ICQ to Doliver Send a message via AIM to Doliver Send a message via MSN to Doliver
Congratulations on the good work guys!
The time we had with some of you here in Brazil was awesome! Looking forward to seeing you again, and good luck in Atlanta!
Douglas
Junior Java Programmer
Yay! Just got hired!
Proud member of ETEP Team #1382
2007 seems to be a nice year, huh?
Regional Winners
Chairman's Award
Best Website
Judges Award at Championship
Team's Website: http://www.team1382.com
Contact Info
E-mail / Msn Messenger / AIM: dolliver@gmail.com
ICQ: 138190550
Unread 09-03-2007, 18:11
Scobrien's Avatar
Scobrien Scobrien is offline
AKA: Steffi :)
FRC #2177 (Robettes)
Scobrien is an unknown quantity at this point
Have you had any issues with being top heavy/ getting knocked by other robots? Otherwise than that, it's an amazing design.
Unread 09-03-2007, 18:49
Carmine Rizzo Carmine Rizzo is offline
Carmine Rizzo is just really niceCarmine Rizzo is just really niceCarmine Rizzo is just really niceCarmine Rizzo is just really nice
We have a very low center of Gravity with the arm descended. We have a high rate of speed to escape. We haven't been upended in the regional.
Unread 09-03-2007, 20:59
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
Originally Posted by AChastain View Post
If your weakness involves getting something stuck in there arm, forget about it. You would need a steel rod to do any kind of damage. Of course, to mount a rod big enough you would not have any weight for a drive so you would sit there, worthlessly. That arm looks unstoppable. Great job.
no thats not it
my strategy is completely legal
but im not going to give all the other teams an advantage
the other defensive robots are just gonna have to figure that out on their own
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 09-03-2007, 23:22
Eric Scheuing's Avatar
FRC #0999 (MechaRAMS)
It looks like a DRAGON!
2015-20XX: MechaRAMS 999
Unread 10-03-2007, 13:36
av11d's Avatar
av11d av11d is offline
College Bum
no team ((Team 75 Alum -- Capt 05 & 06))
av11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to behold
Does it have a name? Or are we back to calling all the robots The RoboRaider?
2003 Animator and FIRST newbie
2004 HP, Animator & Programmer
2005 Team Captain, Arm Operator & Animator
2006 Team Captain
2006 BOSTON ENGINEERING INSPIRATION WINNERS
2006 NJ ENGINEERING INSPIRATION WINNERS
2006 BOSTON AVA WINNERS
2005 DUEL ON THE DELAWARE CHAMPS w/ 222 & 1721
2005 BRUNSWICK ERUPTION IV CHAMPS w/ 358 & 369
Unread 10-03-2007, 16:36
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
We to take tubes from the slot, and find it very fast compared to taking off the floor...
pic: 1058 2007 last pic before ship PVCMike Extra Discussion 6 28-02-2007 14:52
pic: FRC269 2007 #1 Ricky Q. Robot Showcase 4 27-02-2007 09:00
pic: TechnoKats 2007 OI Schnabel Extra Discussion 5 25-02-2007 17:40
pic: Robodox 2007 thewayiam919 Extra Discussion 5 22-02-2007 01:01
2007 Canadian kick-off Jan-6-2007 media coverage Mark Rozitis FIRST In the News... 3 07-01-2007 18:31
