Go to Post What else could you do with a t-shirt? Wait... never mind... I retract my previous statement and realized this is FIRST and we can do anything with anything. ;) - Jeremiah Johnson [more]
Unread 12-03-2007, 10:11
Graham Donaldson's Avatar
Graham Donaldson Graham Donaldson is offline
AKA: Graham Donaldson
FRC #1676 (The Pascack Pi-oneers)
Graham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant future
Re: pic: A Successful Cap in Auto
One of the things I noticed throughout NJ that was almost aggravating to me was how many teams didn't drop their keepers at the end of autonomous, regardless of where they were. Not only is it technically a rule that you have to drop your keeper, but there were many times where if teams had just dropped their keeper, it may have just landed on the spider leg and counted. There was, in fact, one instance where 375 had their keeper DIRECTLY ABOVE the spider foot, but didn't release it. When teleoperated began, they released their keeper before moving. It landed on the spider leg, and the match had to be restarted because the keeper shouldn't have counted. This is my plea to teams: please, DROP YOUR KEEPERS at the end of autonomous- you may just score them.
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
Unread 12-03-2007, 10:17
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Technically, the rule is that if the tube is touching the spider leg and if it would be unsupported by the robot and still be touching the leg, then it was considered scored. So you dont have to let go of the tube if it is supported by the spiderleg in any way.
Min-Max to the Max!
Unread 12-03-2007, 10:18
At least in 375's case (I can't be sure of others), they had their keeper held RIGHT ABOVE but NOT touching the spider leg- just sitting over it. If they had dropped it, it would've counted.
Unread 12-03-2007, 10:20
One T
AKA: Mat
The head ref did an "example" of what was considered scored (At GLR). He said that if the top of the hole was touching the leg then it was counted. I dont know about other regionals but this seems to be a good idea.
Min-Max to the Max!
Unread 12-03-2007, 16:47
ldeffenb ldeffenb is offline
AKA: Lynn Deffenbaugh (Mr)
None #0386 (Team Voltage 386)
ldeffenb has a spectacular aura aboutldeffenb has a spectacular aura aboutldeffenb has a spectacular aura about
Send a message via ICQ to ldeffenb Send a message via AIM to ldeffenb Send a message via Yahoo to ldeffenb
Team Voltage's software group made that decision early on when we read the rules. Why should the drive team have to remember to drop the keeper first? We built a 14 second timer into autonomous to trigger the "score" sequence regardless of where we thought we were. At least it drops the keeper.
Turns out we didn't need it much though. We scored 6 of 8 attempts at our "sweet spot" autonomous. Our finals autonomous was brand new on Saturday morning to make us more compatible with the minor rack rotations and being allied with an autonomous-capable partner. If you watch the finals from the Florida Regional, you'll see just how close we came for our first ever executions!
Lynn (D) - Team Voltage Software and Coach
Unread 12-03-2007, 17:40
Unread 12-03-2007, 17:46
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
At the Finger Lakes Regional, the referees physically took the keepers from robots that did not score them in autonomous before the teleoperated period began. There seems to be a lack of consistency.
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 12-03-2007, 19:04
At the Florida Regional, they seemed to only take away the Keepers that were too close to being scored. If the keeper dropped to the floor or inside the rack, they just left it sit and continued the match.
In one of the semi-finals, the referee entered the field and was removing the keeper when the signal for tele-operated play sounded anyway. You should have seen him scrambling to get off the field!
Lynn (D) - Team Voltage 386
PS. Sorry about the previous duplicate post. I was called away from my PC and didn't realize it had already posted once and now I can't find a way to delete it!
Unread 12-03-2007, 19:25
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
The refs told me they had a reason and rhyme to removing the keepers, but I forgot. It was something about if the keeper moved in the gripper it was taken out.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 12-03-2007, 19:42
That seemed to be the rule of thumb at NJ, Lynn- if they were really close, they would take/pull them away. 375's incident was the first and only time it ever happened (that I remember)- most teams were pretty good about dropping it ASAP, and I think 375 was more a freak accident than anything else.
Unread 12-03-2007, 20:10
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
I agree it is a very good I idea to drop your keeper at the end of autonomous. At NJ a team dropped their keeper while attempting to score on the middle spider and ended up capping it on the lowest one . (I can't remember witch team, If you know i wold love to be informed.)
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 12-03-2007, 20:15
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
That was us, Team 25, during Finals match 2.
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 12-03-2007, 20:55
I remember that!!() But do you guys see what I mean- even if it's not where you intended, it still may end up being beneficial.
[insightful commentary] You'll never get anywhere if you don't try...[/insightful commentary]
pic: Brandon heart auto henryBsick Extra Discussion 18 03-03-2010 10:38
pic: ALMOST cap in autonomous Barry Bonzack Extra Discussion 14 04-04-2005 22:08
Close center cap in Auto JohnBoucher Regional Competitions 10 04-04-2005 18:42
pic: 103vs75 Auto CD47-Bot Extra Discussion 2 05-04-2003 18:48
Upgrade Successful! Brandon Martus Announcements 1 07-12-2002 23:52
