Very clever! That's probably the coolest team souvenir I've seen yet.
Originally Posted by Tom Bottiglieri
It looks pretty impossible. There's no point of reference, and there is only one possible solution (compared to how many for a 6 colored cube?!)
I think the only difference between this and a normal cube is that each of the six center tiles must be in the correct orientation to count as 'solved'. The first five faces should be easy enough to orientate the centers correctly as you go, but the final side may provide some problems. Even so, it'll be right 25% of the time, so you could just mix it up and try again.
