Go to Post I understand that Dean Kaymen has now invented a super "sniffer" that can scout-out anyone within hearing distance that is remotely-involved with FIRST. - dhitchco [more]
Unread 16-03-2007, 22:30
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: pic: Quixilver 604 Ball-Shift Transmission
I like the pattern that matches the Big CIM face. How effective is that for retaining it? I was considering doing that for an update for next season to our base. How else is it held in.
Also, is it just the Big CIM in there?
If it is, are you using all four small CIMs elswhere? If you're not using all 4, what's the reason for going with Big over small.
1. The pattern matching the large CIM is very effective for retaining, as it uses less parts and can handle the motor torque shock. The motor is also held by the metric threaded stud already present on the motor face. One recommendation for anyone interested in this method would be to also drill a hole though the tab for a 1/4-20 screw.
2.Yes, that is just the large CIM. This year our team is going for simplicity, so the transmission is designed around the big CIM 2500 rpm. We did not use the small CIM's anywhere else.
Originally Posted by Andrew Blair View Post
Why the choice to put the shifter on the last stage? Space looks a bit tight, but you could've taken advantage of lower forces on your ball lock.
The reason why the shifter is on the last stage is that there is not enough material on the 20 tooth gears (smallest) for the 1.00" dia. shifter. So the shifter shaft must be on the 40 and 60 tooth gears.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
pic: Quixilver 604 wheels from 2005 Gabe Extra Discussion 2 18-01-2007 22:49
pic: Quixilver 604 frame from 2005 Gabe Extra Discussion 0 18-01-2007 14:57
pic: Quixilver 604 wheel Gabe Robot Showcase 4 31-03-2006 12:06
pic: 222 2005 ball bearing style shifting transmission team222badbrad Robot Showcase 2 11-03-2005 14:17
White Paper Discuss: 222's 3 Speed Shift-On-The-Fly Transmission CD47-Bot Extra Discussion 4 14-07-2004 15:43
