Go to Post FIRST competitions ARE holidays, or they should be at least. - Kel D [more]
Unread 03-18-2007, 11:00 PM
Rohit Roy Rohit Roy is offline
FRC #1002
Rohit Roy is an unknown quantity at this point
Re: pic: 1755 on 1850: 30 easy points
Originally Posted by ChrisMcK2186 View Post
I did not know that was allowed. If they were to build a bot that could latch onto the top of another, would they be able to move if it was secure?
I doubt it. If teams started doing that, they would probably issue an update that says you can't start on top of another robot.
This strategy is amazing because even if you lose, you get 30 tie-brake points.
However, the way I would this is if we took off our arm (which is pretty easy to do) because I would be too scared of another robot hitting us, causing us to fall down. You don't have to ram to knock the other robot off; a light push will do it, and that is likely to happen if opposing teams enter your home zone for ringers.
pic: 60 points IndySam Extra Discussion 6 04-03-2007 08:54 PM
Pic: 60 points Tri_Lam Robot Showcase 15 02-24-2007 11:56 AM
pic: Paul Copioli is worth 3 points! The Cyborg Extra Discussion 11 03-30-2005 12:19 PM
pic: QF match that set new record score = 220 points CD47-Bot Extra Discussion 3 03-29-2004 03:34 PM
pic: YMTC: 150 points or 100 points? CD47-Bot Extra Discussion 4 03-25-2004 01:53 AM
