Go to Post How about "Lebron"? Wait, no, you'll be dooming yourselves to failure the last 30 seconds of every match. - Travis Hoffman [more]
Unread 19-03-2007, 17:22
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
Re: pic: The 2007 Team 703 Phoenix Robot
I have always liked 703's drive train and design sensibilities in general...keep up the good work! I was trying to get 461 to use carbon fiber/nomex panel for the ramps but it didn't work out.
What is the "sandwiched" material in your panels? Nomex? Aluminum? Something else?
Unread 19-03-2007, 17:28
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Thanks, we're very proud of our drive train this year. Our goal was to fix the issues we had had with our tracks breaking in previous years robots, so instead of dealing with all the belts, we just came up with this. It simulates many of the advantages of a tread system and adds the reliability of gears and wheels.
We used Divinycell foam for the sandwiched material as it had much more compression strength than typical Styrofoam but was still very lightweight.
Unread 19-03-2007, 18:09
EricH EricH is offline
That bottom left one better have the ramps slightly out of starting position, or you've got some work at your first event. (If the ramp on the right is in the box, that's an awfully small robot.)
How do you deploy the ramps? Did you keep the arm (I can't see it in the bottom two pictures)?
Unread 19-03-2007, 18:15
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
Are your wheels in a gentle "U" shape? My team is trying to perfect our drive train for next year so we are looking around. Would you recomend this?
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 19-03-2007, 18:19
Grant Cox's Avatar
Grant Cox Grant Cox is offline
Back for more.
Team Role: Tactician
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
sup defensive POWERHOUSE haha. I really enojoyed getting pushed around the rack by that at Detroit
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
Unread 19-03-2007, 18:22
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Yeh, we solved that problem by pulling the ramps in so they fit square inside the starting configuration, We just didn't have the cables attached in that picture.
The ramps get deployed by being retracted up and to the center of the robot by our winch system to a point where they are no longer restricted by the bumpers, our spring hinges then take care of popping them out and we then reverse the winch to allow them to slide out.
It isn't the fastest process (takes about 5-7 seconds to deploy fully) and we had a few issues with it in Detroit which we believe we have addressed (deploying early, getting stuck, ect.).
We did not attach the arm in Detroit, we knew we had to make an new mast for it after we shipped it in order to make weight at the regionals and because the gearing needed to be ajusted, we just never got the time to attach the new mast in Detroit due to all the troubleshooting we did with the ramps.
I'm hoping we can get it on for West Michigan, if not, expect to see it at least once or twice at Nationals.
Chris
Yes, the whole thing is actually in a huge ark. I couldn't tell you the angle right off hand, but its REALLY big. The best part is that the whole thing turns smoothly on a dime!
pic: Team 968 - 2007 Robot Travis Covington Extra Discussion 16 06-03-2007 20:10
pic: Team 1345's 2007 Robot, The Condor. Arefin Bari Robot Showcase 22 23-02-2007 20:18
pic: Team Phoenix - 703 at Buckeye MattB703 Extra Discussion 1 03-04-2006 15:57
pic: Team 703 Phoenix POLISH703 Robot Showcase 6 07-03-2005 12:39
pic: Phoenix 703 "almost done" MattB703 Robot Showcase 13 16-02-2005 14:34
