Go to Post We can relate anything back to water, and by anything, I literally mean ANYTHING. Surfing around on Chief Delphi has proven that to me. - karomata [more]
Unread 23-03-2007, 00:50
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Re: pic: Boilermaker Final Lift
Originally Posted by d.courtney View Post
The rules are too opaque. The fault the rules now possess is if your robot is tipped you are violating rules, are too heavy and should be disqualified because the bumper goes 28 inches high (and then it's both you and the tipper disqualified). Also if the point of reference is the ground as in this case, what allows the bumper of the robot that climbs a ramp to be higher then 8 inches (are we now going to make it illegal to climb ramps when sporting a bumper?).
Also why is this bumper illegal in FIRST's mind? It serves its purpose and just happens to lift at the end.
According to one of the Q&As (paraphrased):
The bumper zone is defined as the space between two planes parallel to the base of the starting configuration of the robot, 2.5 and 8 (or whatever the heights are) inches off of that base.
Thus, when a robot climbs up a ramp, the bumper zone moves climbs up with it. (Search the Q&A for GDC wording if you'd like. Reporting back on how close I was would be cool ;-))
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
pic: Team 234 and 1730 in the air after the winning lift from 1555 to capture the Boilermaker Regional Chris Fultz Extra Discussion 2 22-03-2007 00:00
pic: 1501 Final Robot - see you at BoilerMaker! Chris_Elston Robot Showcase 40 20-03-2005 15:45
pic: The final...final match CD47-Bot Extra Discussion 4 17-04-2003 16:24
A little lift for the final week George1902 General Forum 1 11-02-2003 22:48
