Go to Post So does this mean we can use the FP as bumpers? :D - Peter Matteson [more]
Unread 25-03-2007, 10:14
Billfred's Avatar
Billfred Billfred is offline
Re: pic: Buckeye Regional Pits
Originally Posted by AtalanteStar25 View Post
They did that last year at Las Vegas and this year at UTC. The only reason I can see for this is that the rookies have much easier access to some veterans who can help them with any problems they have. It would also allow them to share resources much easier. Instead of going across the pits to borrow a tool that may have been left at home or to grab a programmer, they just need to lean over into the neighboring pit and tap someone on the shoulder.
I agree, though, it does make it hard to find teams sometimes. At NJ, they stuck with just doing highest->lowest.
Chesapeake, IMHO, had the best pit layout I'd seen, roof leaks notwithstanding. You'd have a whole row of teams in numerical order, then shuffle the rows around until you had a proper mix. So if, say, I was looking for 75, I knew they'd be in the same row as 007--same if I was looking for a rookie team (they'd be in the high-numbered row). It was the perfect blend of mixing the rookies with the veterans and having a layout where you could actually find folks.
pic: Israel regional - working in the pits David55 Regional Competitions 3 29-03-2006 15:06
pic: Great Lakes Regional Pits Joe J. Regional Competitions 12 14-03-2006 19:04
Field in Pits at Lonestart Regional raphael Regional Competitions 0 22-02-2005 19:28
pic: Very Last Match At The Buckeye Regional CD47-Bot Extra Discussion 4 12-03-2003 17:16
Buckeye Regional Shelley_delphi chick Regional Competitions 37 03-03-2003 14:57
