Go to Post You must have a base on which to stand. Knowledge is the base that wisdom stands on. - Steve W [more]
Unread 28-03-2007, 19:16
MasterChief 573's Avatar
MasterChief 573 MasterChief 573 is offline
The Juggernaut
AKA: David McDonald
FRC #0573 (Mech Warriors)
MasterChief 573 is just really niceMasterChief 573 is just really niceMasterChief 573 is just really niceMasterChief 573 is just really nice
Send a message via MSN to MasterChief 573
Re: paper: 2007 Overall Team Rank by Regional Performances
It doesn't look like the champs list has all the teams going to the Championships. What's up with that?
2007 Great Lakes Regional Champs!
2007 Great Lakes Regional #2 Seed
2007 Boilermaker Regional Quarterfinalist
2007 21-8-1 Record
Unread 28-03-2007, 19:42
Am I reading this right? By your spreadsheet 696 is ranked 4th in the country!? Sweet!
Unread 28-03-2007, 20:35
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
First thanks for making this sheet, having all the data is great.
However as a note to every one who intends to use this. This data really holds little value for scouting, just based on the teams I have data on from Boston and UTC I can tell you that the way the teams rank here is not how they would rank for picking.
This is a great resource but using it as scouting data would be a mistake.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 28-03-2007, 20:42
The Juggernaut
AKA: David McDonald
Agreed, this really is no indicator of how teams are gonna do at Championships. I mean probably the really highly placed teams, top tens and such, will probably do good but below that everyone probably just as good a chance as everybody else as far as making it to eliminations.
2007 21-8-1 Record
Unread 28-03-2007, 20:43
I like my RPI better
I plan on putting something together right after this weekend's regionals. Anyone interested?
Unread 28-03-2007, 20:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I would be Tom, but this has some merit as well. This shows the teams ability to win matches (granted a fair bit of that is luck, but it does show strategy and defensive ability). In addition, this weights teams that have played more matches much higher than those that haven't. Both systems suffer based on the exponential scoring system. In Tom's system, a team that places one more tube per match than another will appear to be twice as good. In this, it is not as dramatic, but a single tube can greatly alter your "top score" points (8 tubes gives you a final rating 42 points higher than 7 does). The best system would be a combination of the two (possibly including other data, and some weighting changes), or minimally a spreadsheet containing both sets of data.
Unread 28-03-2007, 22:29
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Some of the individual sheets for regionals have not been sorted by rank yet (as is the case for UTC and Boston). If you could, please sort them and then check your picking order again. I'm curious if it gets any better. I had the data one way, and then tweaked variables - then did not re-sort the rest of the pages, as the individual data gets sorted on the "results" and "champs" page.
www.179swampthing.org
Unread 28-03-2007, 22:51
FRC #5279
I sorted the data. I think that the problem with UTC and Boston is that in Boston some low number teams ranked much lower than they should have because of the large number of rookie and second year teams.
In Hartford some higher numbered teams were fortunate enough to be paired with 2 very good teams due to there being very few newer teams and tons of veterans. I can give you specific team numbers but in the interest of not offending any one I wont post them here. feel free to pm me if you want specifics.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 29-03-2007, 01:36
Vogel648 Vogel648 is offline
Student Programming Leader
FRC #0648 (QC Elite)
Team Role: Student
Vogel648 is on a distinguished road
It seems that using total wins screws over teams that go to fewer regionals, I'd suggest using percentages(really wouldn't be that hard to implement).
Unread 29-03-2007, 09:07
MariaChristineK's Avatar
MariaChristineK MariaChristineK is offline
See you in Atlanta!
AKA: Maria Kretzing
FRC #0291 (CIA)
Team Role: Scout
MariaChristineK is a jewel in the roughMariaChristineK is a jewel in the roughMariaChristineK is a jewel in the rough
Send a message via AIM to MariaChristineK
Hey great job on the total compiling of the results. Even though there are little things that could be improved, it is an awesome spreadsheet! Thanks for making it available to everyone.
The future belongs to those who believe in the beauty of their dreams.
~Eleanor Roosevelt
Unread 29-03-2007, 13:39
Jacob Plicque Jacob Plicque is offline
FRC #0086 (Team Resistance)
Jacob Plicque is an unknown quantity at this point
Cool Re: paper: 2007 Overall Team Rank by Regional Performances
I agree that percentages is a better ranking method since some teams played in more matchs at a regional. Additionally I suggest an 80 point versus 40 bonus for the regional championship alliance since they have won 8 games. Naturally, a finalist would get 60 point versus 20 bonus for the regional 2nd place alliance since they have won 6 games. Overall it is a good effort
Unread 29-03-2007, 18:06
Swampdude's Avatar
AKA: Dan Quiggle
I've added a rev B which now uses a win % x the value, so that will equalize teams with less matches with those who went to regionals with more. I also re-sorted all of the individual regionals. And a bonus I added the current team list for those in Galileo
( I know it will change, but now its ready for the real team lists)
Unread 29-03-2007, 18:48
The Juggernaut
AKA: David McDonald
That's great...where is it?
2007 21-8-1 Record
Unread 29-03-2007, 19:29
hayakuneko's Avatar
hayakuneko hayakuneko is offline
AKA: Joshua
hayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of light
Send a message via AIM to hayakuneko
so did you try to add all of the match results from every regional? or are you just basing this off of each team's most recent regional?
because I only see the match results from the San Diego regional that my team just played in. We also competed in the LA regional which was a few weeks ago...
2007 San Diego Regional Winners (w/ 330 & 835/1216)
2007 Los Angeles Regional Finalists (w/ 980 & 580)
Unread 29-03-2007, 19:42
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You have seperate scores for each regional you attend. Your rating for LA is rated #138.
paper: Team 1281 Team Match Scouting Sheet 2007 astephen68 Extra Discussion 4 26-03-2007 16:41
pic: Team 1070 at the Los Angeles Regional 2007 Joe Ross Extra Discussion 3 18-03-2007 14:32
pic: Team 1251 - 2007 Florida Regional Winners mizscience Extra Discussion 2 11-03-2007 17:28
Best OVERALL drive team Kyle Love Chit-Chat 8 15-04-2005 05:08
White Paper Discuss: Team Regional Perfomance at your finger tips... CD47-Bot Extra Discussion 4 14-04-2004 13:56
