Go to Post Act humble, avoid hubris, and post widely and thou shalt receivith postive rep. ;) - artdutra04 [more]
Unread 30-03-2007, 21:04
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: paper: Midwest Regional Strength of Schedule and RPI
Care to outline some of the theory behind this?
Unread 30-03-2007, 21:29
CJV648 CJV648 is offline
FRC #0648
CJV648 has a spectacular aura aboutCJV648 has a spectacular aura aboutCJV648 has a spectacular aura about
It is inspired by the RPI used to rank NCAA football/basketball teams that tries to correct for the differing schedules of teams. Their approach is to use a combination of own winning pct, opponents winning pct. and opponents' opponents' winning pct. FRC's alliance setup means that we should take into account the strength of alliance partners as well.
To implement this, the spreadsheet calculated a strength of match (SOM) for each team in each match. This is based on the won-loss record of alliance partners less the won loss record of alliance opponents normalized to zero for a nuetral strength match.
Technical considerations: The 1/6 in the cell arithmetic amounts to a dummy 50 pct winning term to replace the team's own record in calculating the SOM. Appropriate subtractions are made from each alliance's win-loss records to avoid bias based on the effect on the teams' records of the outcome of the match being studied.
A team's strength of schedule (SOS) is just their average SOM.
I got lazy with my RPI and just used a weighted sum of winning pct. and SOS
Unread 30-03-2007, 22:01
AKA: Jamie Bliss
Ok.
Did you do all this by hand? Redoing the sheet for the West Michigan Regional is taking a while.
Unread 30-03-2007, 22:27
FRC #0648
I'm a wiz at cut & paste, but formatting the results to fit the formulas is a pain. Give me a little bit and I'll put one up for WMR
Unread 31-03-2007, 19:17
AKA: Jamie Bliss
Seems like you ought to be able to do almost all of it in a script. (Then you could compile numbers using results from every regional!)
Last night, I did all but the last 20 matches in OpenOffice (the last 20 I put in 0's for everything). It's a little nicer, but I lost the sorting (since it can't be done automatically).
This looks like a useful tool for scouting, with some work.
Unread 31-03-2007, 23:51
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
It was pretty interesting to see where some of the teams at MWR were compared to their actual ranking. Just proves how luck prevails.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
White Paper Discuss: 2005 Competition Schedule iheartpi Extra Discussion 2 02-10-2005 04:33
Al Skierkiewicz wins regional WFA Award at Midwest Regional Jaine Perotti Thanks and/or Congrats 30 28-03-2005 15:43
Midwest regional: An offer and a cry for help Manoel Regional Competitions 1 14-03-2005 19:39
Midwest Regional Practice Day Schedule D.J. Fluck Regional Competitions 0 01-04-2003 22:24
2003 Regional Schedule Christine G. Regional Competitions 64 29-08-2002 12:46
