Go to Post ... You order Thunder Chicken Nuggets at the school lunch line - KelliV [more]
Unread 06-04-2007, 23:30
leeweek's Avatar
leeweek leeweek is offline
hamster dance -[418]-
AKA: leeweek
FRC #0418 (Purple Haze)
Team Role: Student
leeweek will become famous soon enoughleeweek will become famous soon enough
Send a message via AIM to leeweek
pic: Powerful Drivetrain - 418
Unread 06-04-2007, 23:35
Skute327 Skute327 is offline
AKA: Alex Symington
FRC #0871 (Robotechs)
Skute327 has a spectacular aura aboutSkute327 has a spectacular aura about
Send a message via AIM to Skute327
Re: pic: Powerful Drivetrain - 418
3 speed dewalts?! very nice how well did they shift? I have bad experiences with stripping the shifting mechanism... I needed the program to "wiggle them in" which was annoying and unprofessional... other than that they are incredibly durable!
Unread 10-04-2007, 00:31
newton418's Avatar
newton418 newton418 is offline
AKA: Ryan Newton
newton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to all
We've never had that problem. One problem we did have was too much friction in one. There is a little clip inside the DeWalt transmission that helps keep the transmission in a given gear (the clip clicks into place). It turned out that the clip on that transmission had been bent at some point, so we simply bent it back to a desirable amount of resistance. Though it doesn't sound like this is the problem you were having, you might want to check it out.
Team 418 Purple Haze
http://www.lasarobotics.org/
Unread 10-04-2007, 01:00
Am I missing the chains, or are the rear two wheels (atleast from this pics pov) not powered.
If so, what effect did this have on driving?
Unread 10-04-2007, 16:36
easponge's Avatar
easponge easponge is offline
You're off the team!
AKA: Betsy Soukup
FRC #0694 (StuyPulse)
easponge is an unknown quantity at this point
Yeah, it sort of looks like only the front four wheels are powered. Are the back two just for balance, or is there some crazy mechanism that hooks up the motor controlling the arm to those wheels?
Unread 10-04-2007, 17:13
newton418's Avatar
AKA: Ryan Newton
There are 2 chains inside each piece of box aluminum. These chains connect the center axles to both the front and back axles. Though the back and center wheels are both powered, connecting them does several things:
1) If one or two of the wheels is not in contact with anything, the remaining wheels will still be powered by both motors
2) Since the back wheels probably have less traction than the combine traction of the middle and front wheels, it prevents the back wheels from slipping while the center motor struggles to provide enough torque to the middle and front wheels
3) If, for some reason, we lose power from one of the motors, all wheels are still powered (though we'd probably have to run in 1st gear for the rest of the match)
Though the chains were difficult to access, putting them inside the box aluminum saves us room, protected the chains, and provided a rigid structure. As a result we never needed to service the drive train during LSR.
Unread 10-04-2007, 19:18
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Holy jumpin' catfish! That's a lotta oommph!
Richard Wallace
since 2003
pic: Purple Bumpers - 418 leeweek Extra Discussion 5 05-04-2007 00:12
pic: MiniMeet - 418 & 2158 leeweek Extra Discussion 2 04-04-2007 12:32
pic: The gearbox that makes us so powerful keenanmolner Robot Showcase 6 20-02-2007 02:11
pic: Fischer Price motor are very powerful CD47-Bot Robot Showcase 15 17-03-2004 20:22
pic: Attacking the stack vs 418 and 57 in match 68 CD47-Bot Extra Discussion 0 08-04-2003 20:10
