Go to Post F.I.R.S.T. Troubleshooting Rule #1 - If you work on software, the problem is always with hardware. If you work with hardware, the problem is always with software ;) - Redneck [more]
Unread 09-04-2007, 22:32
vadyr's Avatar
vadyr vadyr is offline
103 Alumni/Mentor - FIRST Volunteer
AKA: Bobby
no team (Cybersonics (Mentor))
vadyr is a jewel in the roughvadyr is a jewel in the roughvadyr is a jewel in the rough
Send a message via AIM to vadyr
Re: pic: 25 Base Bot Climbs 1089
Originally Posted by Wayne C. View Post
Arefin-
there is no need to sell it. The plans are in the new book- for the most part.
With a little luck we will be helping a lot of teams make them over the coming summer.........
WC
heh...we took a page out of your books and tried the 6 wheel drive again...i dont think we used any of the plans, we just tried our own 6 wheel after seeing and running with you guys for the past few years....after winning NJ last year, we realized that those caster had to go! with that said, i know 25 has been a big help to other teams and their drivetrains, but 103 is also available for questions...check us out in galileo!
www.cybersonics.org
Unread 10-04-2007, 00:12
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
6wd isn't a problem for team 1345. I just would like to know how to turn on dime without lowering your middle wheel. Thank you for your offer and I will definitely like to look into the chassis you guys designed this year. =)
Unread 10-04-2007, 00:17
EricH EricH is offline
What about a slightly (just slightly) larger center wheel? That would slightly lower the center (less than a lower hole), but could be compensated for. Then again, you would run into issues with the wheels running different speeds. (Easily solvable, but not pretty if not solved.)
Unread 10-04-2007, 00:22
AKA: Ari
You are right, but I was told that team 25 never lower their middle wheel when they design a 6wd. I would like to know how...
Unread 10-04-2007, 00:52
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
A lot of thought go into our machines. The simple answer to why we can do that is 'Brute Force'. But I am sure you do not want to hear that. We pay close attention to detail - the materials we use for gears and the alignment/construction of the drive train. We do all this simply to ensure peak performance or in engineering terms - efficiency. Another thing we do is make the drive train as modular as possible. Therefore, if we do make a mistake, we have a chance to correct ourselves during the season without any major re-designs.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 10-04-2007, 00:57
I know this has been asked and answered before, but what is the benefit to this?
If I remember right, it causes you to bounce while turning (atleast it did last year)... Isn't that hard to control?
I know you have good reasons for it, enlighten us.
Unread 10-04-2007, 00:59
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Haha, the famous (or infamous) "brute force."
Psssst, people......guess what....it works.
Unread 10-04-2007, 01:01
Depending on the game, or event, we configure our robots to suit our needs. This year, our outer wheels were cut slightly smaller than our inner wheels so we could turn easy. Last year, it was not that easy to push us around which allowed us to shoot the balls in the goal when needed.
-= Bharat Nain =-
Unread 10-04-2007, 01:04
So, since it takes x amount more force to turn, It's that much harder for other teams to turn you?
That makes a great deal of sense actually. Taking a problem that has plagued inexperienced teams and using it (with precise calculations I'm guessing) to your advantage.
Unread 10-04-2007, 06:44
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
Absolutely. Having great precision allows maximum efficiency output from the time the current is applied through the circuit box to the time the wheels hit the floor. But as Bharat said, modularity is also key.
If you get a chance, stop by our pits in Galileo and see, but our entire motor setup is rather flexible. With multiple input shafts on each side, we can shift the motor plates to any of multiple locations depending on where we want the weight and placement to be. This year with our mast in the front it was beneficial to have more weight towards the back and so our mounting is reflective of that. Each of the plates has a spot for the servo brakes and only one brake needs to be inserted per side to effectively lock down the entire drive train.
Because our transmissions are modular as well, and rather small in size, it allows for easy changes in gearing depending on what the game calls for--they simply "pop in and out".
Finally, from the time we first started using gear driven drive trains we've learned from our mistakes and improved on future bases. Each year its modified as we see fit, but the underlying principles for each remain the same--simplicity, simplicity, simplicity.
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
How & where do you build the bot when it snows and your robo-base (school) is closed? Elgin Clock General Forum 28 03-03-2008 00:12
pic: 1089 and 237 Battle It Out BandChick Extra Discussion 4 22-05-2006 23:29
pic: Team 1089 BandChick Extra Discussion 3 03-05-2005 01:36
pic: Rachel climbs a tree... 1018 Bob Steele Robot Showcase 8 23-02-2005 09:51
Segway climbs a mountain Katie Reynolds Dean Kamen's Inventions 1 28-08-2003 13:41
