Go to Post I think it would be beneficial for us frogs to be in the new hopper division - zsm150 [more]
Unread 18-04-2007, 18:30
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
pic: 1683 8 wheel drivetrain completed
Unread 18-04-2007, 18:31
Re: pic: 1683 8 wheel drivetrain completed
Looks good overall...
just a few questions.
-Weight?
-Speeds?
Also, it looks like you have live axles going into bushings rather than bearings. Wouldn't bearings be better and have a lot less friction?
Unread 18-04-2007, 19:56
CraigHickman
Looks good, but keep in mind one thing: if you're doing static wheels, your tensioner needs to be very precise, or you may have chain issues.
Also, I high recommend swapping the bushings out for bearings. You'll notice a huge performance increase. I built our 06 drivetrain in bushings, and I'm never doing it again.
Unread 18-04-2007, 20:16
MrForbes MrForbes is offline
I wonder how igus bushings would work for the drivetrain? just an idea...they seem to be "good stuff" and worth considering using wherever you can.
I don't see nearly enough room for electronics
How much work is it to change a wheel out?
Unread 18-04-2007, 21:14
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
Just a question would it be tank or skid steering.
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 18-04-2007, 21:37
EnderWiggin's Avatar
EnderWiggin EnderWiggin is offline
07' Co-Team Leader
AKA: Carl Partington
None #0610 (The Coyotes)
EnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud of
Every good 4+ wheel drive train has an odd number of wheels on each side. This is because the center wheel is dropped to allow the robot to "spin on a dime" because it rocks on the center
When you start pushing someone or they start pushing you, the robot basically turns into a 4 wheel drive system by falling to one side. Either the front or back wheels barely touch the ground when this happens.
In your system here, you COULD drop the two sets of center wheels if you so desired (this is what team 48 did with their tank drive system) but i doubt it would rock very well on those four wheels unless you move them closer together.
Unread 18-04-2007, 21:48
AKA: Sean
We used bushings this year and they seemed to work very well. Switching out to bearings would work but the cost would be much greater, also how thin of bearings can you buy? I am wondering because the plates are only .25" thick. I do agree that they would probably be more efficient, but honestly bushings worked so well for us and really didn't have much friction. I will definitely look into bearings though.
The total weight for the drivetrain is around 40lbs. I believe each module is about 17lbs in inventor. That weight is with motors. It uses the andymark 2 speed transmissions, and on the design as pictured the speeds are around 5fps and 12fps, but we might up the speed a little.
The 2 middle wheels are lowered on each side to provide some rocking effect. There shouldn't be much problem with it turning as the middle wheels have a larger track width than the length. Essentially it is a wide 4 wheel drive base which generally doesn't have any problems.
Mentor 2415
Unread 18-04-2007, 21:55
CraigHickman
We used bearings for half inch shaft that were .25 thick total, and 1/16th of that was a flange, so press fitting isn't necessary. We still press fitted them for more security though...
Unread 18-04-2007, 22:00
AKA: Sean
Could you tell me where you got them from and how much. The thinnest I can find are 7/16". 1/4" would be perfect and would allow us to press fit them. Also why do you not like bushings? Multiple teams use them including 121 and they seem to work well. Just wondering. Thanks for your help.
Mentor 2415
Unread 18-04-2007, 22:02
Alpha 997 Alpha 997 is offline
AKA: Yi Li
FRC #0997 (Spartans)
Team Role: Operator
Alpha 997 will become famous soon enough
Agree. I'm sure you are going to need more room for electronics.
Ohhh... The EXIT sign is green so that robots can get out during a fire.
2007-Archimedes semi-finalist
2007-Davis Sacramento Regional champion
2007-Pacific Northwest Regional champion
2005-Archimedes semi-finalist
2005-Archimedes second seed
Unread 19-04-2007, 00:42
His method of dropping the four center wheels will work just fine. Several teams have done this before and it provides the performance of a 6 wheel while eliminating any possible rock that some drivers find annoying.
Unread 19-04-2007, 00:52
CraigHickman
I can't find the flanged ones right now, but as for normal ones, you can get them from McMaster. The part number for an open one is 60355K15, the shielded is 3760T15, and the double sealed is 3760T31. If you go with these, you'll need to pocket the hole so that the bearing won't get forced out in a heavy defense match. Either that or search around for a bearing maker that sells flanged ones.
Unread 19-04-2007, 02:20
AKA: Sean
I looked at mcmaster and I saw those bearings. If I were to use bearings over bushings, they would have to be flanged, and be thinner than 1/2". Also I can't tell if the electronic thing is a joke or not but I think there's plenty of space for electronics. The controller will probably be on a second layer above the rest of the stuff.
Mentor 2415
pic: 1683 8 wheel drivetrain updated sdcantrell56 Extra Discussion 10 16-04-2007 18:08
pic: 1683 Concept 8 Wheel Drive sdcantrell56 Extra Discussion 16 16-04-2007 14:22
pic: 1683 robot 2 sdcantrell56 Robot Showcase 7 15-02-2007 21:54
pic: 1683 drivetrain 1 sdcantrell56 Extra Discussion 11 01-02-2007 11:24
pic: 1683 2007 drivetrain sdcantrell56 Extra Discussion 9 17-01-2007 17:32
