Go to Post As long as this is a competition teams will push the limits. Those that succeed are those who can push the envelope and still stay within the lines. - Steve W [more]
Unread 22-04-2007, 19:33
1359th Scalawag's Avatar
1359th Scalawag 1359th Scalawag is offline
AKA: Eric
FRC #1359 (The Scalawags)
Team Role: Marketing
1359th Scalawag is just really nice1359th Scalawag is just really nice1359th Scalawag is just really nice1359th Scalawag is just really nice
Re: pic: All Terrain Swerve 1
It looks really cool!
I've never thought about doing 4 little tank drive systems before. Was this a design you used for an actual robot you used in competition or is it just an idea?
The only thing I could see that looks like a problem would be the placement of the cims. Might the cims on the left be better on the inside too? When driving by something, they look like they might be hit.... I dont know. I have no experience in that area.
Unread 22-04-2007, 19:46
CraigHickman
Wow. Very impressive. One suggestion: You're going to have trouble turning. I suggest using the Mini Bike motor through a really torqued out gearbox to steer, as those won't be able to turn that thing.
Very nice!
Unread 22-04-2007, 19:57
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
Looks to me as if each module rotation point are going to be very hard to keep from breaking. I think theres too much leverage under the rotation point, maybe im wrong.
way to think different though.
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 22-04-2007, 20:39
run the trap!!!
Team Role: Human Player
I think your real turning problem is going to be draaaaging those high-traction treads around on a smooth surface.
Why not reduce the area of contact between tread and floor?
This was an old idea from 2004 (see thread >here). The treads had only a small area of contact with the floor - but a large area of contact with oncoming obstacles.
-Philip J. Fry
Unread 22-04-2007, 21:05
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
I don't think this was an old idea from 2004, but rather an idea from an old robot in 2001 (http://www.chiefdelphi.com/media/photos/12374).....I think some of you might know the team....
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Thanks for all the interest
I admit that the CIM's are very close to the ground, however, the treads aren't very wide at the moment and it would be easy to go or 3 inch treads instead of one and a half inches. As for the CIM's being on the outside that was just a mistake on my part and I will fix that soon
I have thought a lot about the turning problem and had a couple of ideas. I thought about using another set of motors on each module to lift it up onto just one of the two pulleys. I also thought about making the shock absorbers to out of pneumatic cylinders, and put valves on it so that it could lift the modules onto one pulley. The other advantage of these is that it would make it easier to get up ledges.
I do like the idea of using three pulleys to get one point of contact but I'm weary of this because it wouldn't be stable in this set up with the second axis of turning. This is actually just a fun little CAD project that I'm working on. I'm trying to put together a bunch of different wierd drive trains together to give the younger kids on the team some ideas for next year.
Again thanks for all the input
Unread 22-04-2007, 21:15
artdutra04's Avatar
VEX Robotics Engineer
So far this looks like a really neat idea.
The only problems I see that might be a problem with going offroad and all-terrain are the lack of ground clearance between the CIM motors and the ground, the "exposed" gears on the outside of the modules (although protected from the side, there's nothing on the bottom to prevent sand or grime from getting in there), and maybe the treads themselves.
I'd probably consider much wider treads with more traction to them, so that if traveling through something like sand, snow, or mud they don't sink out of sight. (Ever try to ride a bicycle through deep mud?) Wider treads will spread out the weight of the robot better, allowing for the robot to glide over the obstacles instead of sinking into them.
Point contact would a complete 180 of what you need when going off-road and all terrain. You need more contact with the ground, to better spread out the load so you don't sink into the ground.
No it won't. This robot should have an excellent time turning, and I don't see any problems with it as is. In fact, with some sophisticated code it can be even more agile than a traditional swerve drive in it's ability to do complex curves and arcs without any side scrub.
All of the four swerve modules are all independently driven, which means you can have all your wheels turn in different amounts to almost perfectly turn using Ackerman steering. Since every wheel can turn independently, each wheel can turn the exact amount needed to eliminate any and all side scrub. Here's a quick illustration:
...Which would work exactly the same as the Jeep Hurricane concept car:
http://video.google.com/videoplay?do...03950591957346
Art Dutra IV
世上无难事,只怕有心人.
Unread 22-04-2007, 21:19
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
http://www.robots.org/images/NASA_Am...yMarsRover.jpg
Unread 22-04-2007, 21:20
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
...I want one!
Unread 22-04-2007, 23:03
CraigHickman
Actually, if the motor couldn't even spin the tread (which it wouldn't, those things have practically no tourqe) then being able to do those complex curves wouldn't really matter. I was referring to the motor choice to spin the actual module, not the over robot turning ability.
Unread 22-04-2007, 23:26
Fidgetting
I don't see how those motors don't have much torque. The CIM's have more than enough power for the drive on a 40-60 pound bot and the fisher price through a 256 reduction should have like 60 ftlbs. of torque which should be more than enough.
In any case the robot should be moving when turning the modules which will significantly reduce the turning force
Unread 23-04-2007, 15:36
David Guzman's Avatar
AKA: Dave
FRC #1251 (The Techtigers)
I think you need to work out your numbers again. The motors have quite a bit of torque. We used them to pivot our arm, which takes more torque than turning those modules. The only problem I do see with this motors is overheating, but thats a different story. In the end we changed them for globes but only because of the overheating problem. They had sufficient of torque.
Team 1251 The Techtigers
Unread 23-04-2007, 18:11
kibbs425 kibbs425 is offline
AKA: Kyle Henry
FRC #0125 (Nutrons)
kibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to behold
Send a message via AIM to kibbs425
If your really looking at doing this you may want to see about putting all of your gears in an enclosed gearbox with an output shaft that chain drives the wheel pulleys. This will help keep the gears clean and running better, i.e. not wearing down teeth because of grit contaminant. Also look at getting sealed bearings, with REALLY good seals. Girt contaminants can easily destroy any rotating part.
Since 2002
Unread 23-04-2007, 16:07
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
I still can't understand how it matters how much torque it will take to turn those modules, as of the current rules, there are not 4 FP allowed.
this is in fact very true that it will not take much force to turn the modules, you might as well just use 2 BB motors and 2 globe motors.
Unread 23-04-2007, 16:17
Brandon Holley's Avatar
I think this is being considered as a side project...not necessarily for competition
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
pic: Vex Swerve Vince lau Extra Discussion 10 19-03-2007 10:08
pic: Vex Swerve v3 JVN Extra Discussion 22 08-09-2006 17:28
pic: Swerve! =Martin=Taylor= Extra Discussion 15 07-07-2006 01:58
Splines, terrain, and conformity Daishichimaru 3D Animation and Competition 1 06-02-2002 19:34
