Go to Post Nothing beats the local hardware store :). - Mike Martus [more]
Unread 23-04-2007, 15:36
David Guzman's Avatar
AKA: Dave
FRC #1251 (The Techtigers)
Re: pic: All Terrain Swerve 1
Originally Posted by 114ManualLabor View Post
(which it wouldn't, those things have practically no tourqe)
I think you need to work out your numbers again. The motors have quite a bit of torque. We used them to pivot our arm, which takes more torque than turning those modules. The only problem I do see with this motors is overheating, but thats a different story. In the end we changed them for globes but only because of the overheating problem. They had sufficient of torque.
Team 1251 The Techtigers
Unread 23-04-2007, 18:11
kibbs425 kibbs425 is offline
AKA: Kyle Henry
FRC #0125 (Nutrons)
kibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to behold
Send a message via AIM to kibbs425
If your really looking at doing this you may want to see about putting all of your gears in an enclosed gearbox with an output shaft that chain drives the wheel pulleys. This will help keep the gears clean and running better, i.e. not wearing down teeth because of grit contaminant. Also look at getting sealed bearings, with REALLY good seals. Girt contaminants can easily destroy any rotating part.
Since 2002
pic: Vex Swerve Vince lau Extra Discussion 10 19-03-2007 10:08
pic: Vex Swerve v3 JVN Extra Discussion 22 08-09-2006 17:28
pic: Swerve! =Martin=Taylor= Extra Discussion 15 07-07-2006 01:58
Splines, terrain, and conformity Daishichimaru 3D Animation and Competition 1 06-02-2002 19:34
