Go to Post Back in the old days, we didn't have clues, and we liked it! - Joe Ross [more]
Unread 25-04-2007, 15:41
Rich Ross Rich Ross is offline
Let's get Desperate!!!
AKA: 830 Alumni
FRC #1504 (The Desperate Penguins)
Rich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond repute
Send a message via AIM to Rich Ross
Re: pic: All Terrain Swerve Updated
First off, amazing! I wish i were better at CAD! I hope to learn someday how to build my ideas, turning them into something that others can see more readily.
Can we get some size specs? how long is each tread section? Where are you going to obtain said tread? What sort of material is the superstructure?
Thanks in advance i hope...
1504, finalists WMR and judges award GLR
Let's get Desperate.
Unread 25-04-2007, 18:47
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
That's really cool!
How does the middle bar work? In what way is it connected?
2007 - NASA/VCU Regional Winners (Thanks 2108 & 843!)
2006 - Championship Curie division
2006 - NASA/VCU Semi-Finalists (Thanks 510 & 587!)
2005 - NASA/VCU Quarter-Finalists (Thanks 388 & 619!)
Unread 26-04-2007, 20:27
dtengineering's Avatar
AKA: Jason Brett
Nice design... but watch your assumptions on the FP/Banebots combo. I get the sense (now I'm the one making assumptions) that you are using the peak torque figure for the FP when calculating your output. FP's don't last long at peak torque. Since this motor will be in intermittent operation and you have calculated a factor of four over your peak design load, you will probably be okay, but I normally calculate FP torque based on a 10 amp load... and even then plan to provide cooling for continuous operation.
Secondly the little BB 256:1 gearboxes have the ability to pull themselves apart when driven to the peak torque of an FP. I highly doubt that 10 ftlbs would be a problem, but 40 is starting to get up there.
So assuming your load calculations are correct, your design should still work, but I don't think you have nearly as much "extra" torque to work with as you have calculated.
Here's a suggestion that came to mind the first time I saw this design... why not also pivot the tread modules about one of the rollers. That way you could also lift the robot up onto "tiptoe" when more ground clearance is needed. No reason it couldn't be done with pneumatics if you didn't want to slip another motor down there.
Jason
pic: All Terain Swerve 2 Alex.Norton Extra Discussion 8 23-04-2007 21:57
pic: All Terrain Swerve 1 Alex.Norton Extra Discussion 17 23-04-2007 18:11
pic: Swerve! =Martin=Taylor= Extra Discussion 15 07-07-2006 01:58
Splines, terrain, and conformity Daishichimaru 3D Animation and Competition 1 06-02-2002 19:34
