Go to Post When you tell any of your kids that winning isn't important, or isn't [I]that[/I] important, the flapping sound you hear is your credibility flying away. - jlindquist74 [more]
Unread 25-04-2007, 21:50
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
Re: Need help from turret experts
1351 made a turret both this year and last year.
Note: I will use "turret" and "turntable" to describe the same thing
The turret on our robot for the 2006 competition was of much use. The ramp in 2006 was slippery and narrow. It was quite dangerous to move around up there because the robot might get stuck or even tip over.
We would get up onto our opponent's ramp and not even worry about robot positioning because we have a turret to compensate for any misalignment of the chassis. It worked very well and was very useful.
This year, we designed a turret at the base of an arm that was supposed to be comprised of two 5.5 foot articulated sections. I'm not entirely sure what we called it but we modled the turret around how a car wheel is attached to a drive shaft.
In my opinion it was the most useless thing ever. We never got our arm to work to "requirements documents" specifications. The arm turned out much shorter and lighter. Still, it was a very slow device. The chassis could realign itself faster than the turret to move.
Now an example of a good turret would be team 692. They also had a turret but instead of mounting their entire arm on it like we did, they integrated their turning system at the very top of their arm. That way the thing didn't have to be strong enough to carry the weight of an 11 foot flailing arm. Instead it worked fast and smooth because it wasn't bearing too much weight.
The moral of the story is: only use a turret if you need to achieve some sort of movement and/or orientation that your chassis can not. Don't throw one on for the heck of it and unless your team is incredibly beastly, completely ignore the words "cool factor". Coolness does not outweigh functionality.
Hope this helps,
Sam
Unread 25-04-2007, 22:16
Alpha 997 Alpha 997 is offline
AKA: Yi Li
FRC #0997 (Spartans)
Team Role: Operator
Alpha 997 will become famous soon enough
Smile Re: Need help from turret experts
Hope this helps,
Sam
Thank you for the great advise.
Ohhh... The EXIT sign is green so that robots can get out during a fire.
2007-Archimedes semi-finalist
2007-Davis Sacramento Regional champion
2007-Pacific Northwest Regional champion
2005-Archimedes semi-finalist
2005-Archimedes second seed
Need Help Making Part from Spec Goaliexam Inventor 10 26-07-2006 11:34
need a general opinion from all you experts... archiver 2001 3 23-06-2002 23:09
Need Help, from Mentors for Research Steve Shade General Forum 1 25-02-2002 15:49
I need Help from you all. nick reynolds Chit-Chat 18 02-11-2001 23:39
