Go to Post Whether or not your team has the technical mentors, as long as your kids are still inspired by the adult technical mentors of other teams, and get the picture that we're trying to portray in this program, the best that you can do is the best you can do. Do it, and be proud of your results. - Beth Sweet [more]
Unread 27-04-2007, 13:56
les chortos les chortos is offline
FRC #0773
les chortos is an unknown quantity at this point
Re: pic: Cooney 269's Worm Crab Gearbox Interior
The problem with Worm drive on the main wheels is that Worm drive is very ineffecient. What this means is that it draws a lot of battery power to drive the wheels. Last year team 772 . used a worm and wheel and at the start of a match could drive up last years ramp- ( the ball shooter ramp) . but at the end of the match after they run the battery down for 2 mins. could not.
Worm and wheel is good for high reduction ratios and if the worm pitch is choosen properly- self locking. - that a bout it.- they are generally high is sliding friction and cannot coast. If you want a "coastable" robot - do not use it.
In a nut shell- don't waste your time.- if it was good all the good teams would be using it.!
FRC 269 Worm Crab 2007 Video Ricky Q. Robot Showcase 3 21-02-2007 20:59
pic: 269's Underwater Robot AndyB Extra Discussion 9 07-10-2006 18:19
pic: 269's Westin Battery Farm Ricky Q. Extra Discussion 4 02-05-2006 07:16
pic: Team 269's 2006 Robot - Annie Oakley Ricky Q. Robot Showcase 3 21-02-2006 16:30
Worm Gear Gearbox dddriveman Technical Discussion 38 07-01-2005 14:43
