Go to Post You know you are a true tech geek when you end up on top of the Sears tower, and the only pictures you post are the ones of the radio antennae. ;) - Tom Line [more]
Unread 04-27-2007, 10:41 PM
run the trap!!!
Team Role: Human Player
Re: pic: Dual Wheel Swerve-Drive
Stats:
-Each module is made from 1 piece of aluminum.
-Uses 8, 4" Colson Wheels
-Without Banebots & Motors the base is only 6" high
-Each module is aprox. 5x5x5"
-Notched corners will allow it to climb ramps at an angle.
-8 fps., rotated by (2 or 1?) globe motors.
-Weight = ??? (I estimate 50 lbs.)
It’s a work in progress. I hope to make the modules a bit narrower, and I still need to figure out a good chain path to rotate the modules.
It should be pretty simple to build; seeing how it would only need 1 axel and two miter gears to be machined per module. Of course the BB's would require new carrier plates...
Comments and input appreciated.
-Philip J. Fry
pic: Coaxial Swerve drive, lightened. CraigHickman Extra Discussion 19 06-22-2006 03:00 PM
pic: Dual omni-wheel Richard Wallace Extra Discussion 17 12-05-2005 10:38 AM
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 02-18-2005 08:24 PM
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 09-03-2003 10:40 AM
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 06-26-2003 04:19 PM
