Re: pic: Dual Wheel Swerve-Drive
I still don't think you can go up ramps corner first (or very well at all with that low ground clearance, but that's a different matter). If you lead with a corner, you're going to lose contact with one (or both) of your adjacent corner wheels.
Say you lead with your "north" corner, then you will lose contact with your east and/or west corners as you go up the incline. If your CG is low enough, and your base stable enough, with enough torque in each module, this might not be a problem, it would just be a bit scary (and possibly arc depending on how you steer it). |
| pic: Coaxial Swerve drive, lightened. | CraigHickman | Extra Discussion | 19 | 06-22-2006 03:00 PM |
| pic: Dual omni-wheel | Richard Wallace | Extra Discussion | 17 | 12-05-2005 10:38 AM |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 02-18-2005 08:24 PM |
| White Paper Discuss: Dual-motor, dual-speed drive transmission design | CD47-Bot | Extra Discussion | 9 | 09-03-2003 10:40 AM |
| pic: Lego Swerve Drive | CD47-Bot | Robot Showcase | 14 | 06-26-2003 04:19 PM |
