Re: pic: Homemade Keyway Broaches
beautiful! thanks for showing us such a neat idea
very slick! now if only there were a way to make hex broaches like this...
If I get access to a manual lathe with a three jaw chuck then that will be my next project...
One year at GLR we had to put a keyway into a sprocket, and we didn't have a broach or a press in the pits. So we taped about 5 hacksaw blades together, and slowly cut the keyway into the sprocket. Took awhile, but worked out just fine.
It also cost us 5 hacksaw blades. |
Here is a photo of what else I did. I keyed two of these hubs as well as cutting a key slot in the drive shaft with a Dremel carbide cutter. Took a while, but it works!
| HomeMade Motor Controllers | John Gutmann | Electrical | 19 | 06-08-2007 18:06 |
| Homemade parts | Arkorobotics | FIRST Tech Challenge | 6 | 17-05-2006 22:54 |
| Standard keyway broach in a metric bushing | sanddrag | Technical Discussion | 2 | 18-02-2006 01:17 |
| Homemade Robotics Clothes | Jill1022 | General Forum | 9 | 28-03-2005 14:57 |
| Need help designing keyway in gear | sanddrag | Technical Discussion | 17 | 31-01-2005 08:43 |
