Go to Post Gosh, I wish that we would've named IndianaFIRST after a candy. - Andy Baker [more]
Unread 29-04-2007, 14:56
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: pic: Homemade Keyway Broaches
Originally Posted by Nuttyman54 View Post
very slick! now if only there were a way to make hex broaches like this...
If I get access to a manual lathe with a three jaw chuck then that will be my next project...
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 29-04-2007, 15:23
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Not2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond repute
One year at GLR we had to put a keyway into a sprocket, and we didn't have a broach or a press in the pits. So we taped about 5 hacksaw blades together, and slowly cut the keyway into the sprocket. Took awhile, but worked out just fine.
It also cost us 5 hacksaw blades.
Brian Graham
Unread 19-05-2007, 20:28
Gabe's Avatar
Here is a photo of what else I did. I keyed two of these hubs as well as cutting a key slot in the drive shaft with a Dremel carbide cutter. Took a while, but it works!
HomeMade Motor Controllers John Gutmann Electrical 19 06-08-2007 18:06
Homemade parts Arkorobotics FIRST Tech Challenge 6 17-05-2006 22:54
Standard keyway broach in a metric bushing sanddrag Technical Discussion 2 18-02-2006 01:17
Homemade Robotics Clothes Jill1022 General Forum 9 28-03-2005 14:57
Need help designing keyway in gear sanddrag Technical Discussion 17 31-01-2005 08:43
