Go to Post Ohhh Chiefdelphi how I love you and your 700 posts about a picture of a fish. - Boydean [more]
Unread 30-04-2007, 07:33
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Re: pic: A more standard aproach
I agree with Aren, although we use two Globes for steering. I would stay away from the Banebot transmissions that appear in the steering motors. They might not be able to handle the rough treatment when your robot gets hit from the side or bangs into something.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 30-04-2007, 07:52
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
FIRST off, if you need any help with G-Code programming or machining in general just hit me up...
I'm wondering... does that 64:1 gearbox with the mabauchi motor have enough torque to turn the wheel under load?
A suggestion to save weight, for 1/8" polycarbonate you can use a large pop rivet to save weight as well, not to mention the higher population of fasteners will more evenly distribute the forces on the stiffening plate over a larger portion of its perimeter.
Very nice lightweight design, have to say, amazed that all those gears for four wheels only weigh 35lbs.
-q
Electrical Engineer Illini
Standard vs. Custom Frame brennerator Technical Discussion 62 23-12-2006 22:54
Standard Joysticks EricWilliams Programming 26 01-04-2006 22:59
Standard Servos? Matt Krass FIRST Tech Challenge 4 22-11-2005 08:09
Developing a standard Jack Scouting 23 03-01-2003 23:04
