Go to Post Congratulations to team 341, your work is nothing short of what I want to do when I grow up. - kjolana1124 [more]
Unread 30-04-2007, 07:52
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Re: pic: A more standard aproach
FIRST off, if you need any help with G-Code programming or machining in general just hit me up...
I'm wondering... does that 64:1 gearbox with the mabauchi motor have enough torque to turn the wheel under load?
A suggestion to save weight, for 1/8" polycarbonate you can use a large pop rivet to save weight as well, not to mention the higher population of fasteners will more evenly distribute the forces on the stiffening plate over a larger portion of its perimeter.
Very nice lightweight design, have to say, amazed that all those gears for four wheels only weigh 35lbs.
-q
Electrical Engineer Illini
Standard vs. Custom Frame brennerator Technical Discussion 62 23-12-2006 22:54
Standard Joysticks EricWilliams Programming 26 01-04-2006 22:59
Standard Servos? Matt Krass FIRST Tech Challenge 4 22-11-2005 08:09
Developing a standard Jack Scouting 23 03-01-2003 23:04
