Go to Post Girlfriend? What is that? A rare Pokemon? - DanielPlotas [more]
Unread 30-04-2007, 11:09
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Re: pic: A more standard aproach
I'm using 8 motors in the drive for a couple of reasons. I like the idea of the extra maneuverability and control that is provided, i know that this is more complicated program wise but it is less complex mechanically and is lighter. Two motors weighs less than a chain tensioner plus chain and sprockets. Mechanically it is much easier cause I don't have to mount everything separately and all the pieces are the same and there are fewer of them.
The motors would be two Fischer Price and two BaneBots (don't know if we have all these next year so...). I'm pretty sure that the trans could handle the load because there is a bearing at the bottom that all upward force and most lateral force would go into. I would worry a little about the carrier plate but if the modules are well protected I don't think it would be a huge problem.
I got rid of the suspension cause of weight and the suspension is really complicated. I really liked the idea but it didn't seem needed for an actual first robot, plus this is much lighter and more importantly costs about half as much. The wheels cost $2.75 each instead of $100 each. And when I say "that which is shown" I forgot that I was only showing half of the bot. The entire thing, modules, motors, frame, everything weighs only 35 pounds. Of course with electronics this could be 10 pounds heavier but that still leaves much more than half the allowed weight to build on top of.
Orders... jee hadn't thought of that.
Thanks for the offer of help but I think I can handle it, however if I do need help. If you would like to CAD files just ask.
Thanks very much for all the input.
Unread 30-04-2007, 11:36
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Alex,
One thought I had after my intitial post is the problem of keeping the steering motors in alignment. It is an issue using two motors and chain for us. To keep all four tracking is going to take some processing power and sensors.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 30-04-2007, 21:54
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is online now
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Just out of curiousity, how do you keep the wires on the drive motors from tangeling around the sverve module?
Unread 30-04-2007, 22:24
We limit the travel to only one rotation plus a few degrees, max. This year we closed that down even further. The wiring comes right up out of the top of the module and the upper bearing point is a hollow tube which the wires run through.
Al
WB9UVJ
www.wildstang.org
Unread 30-04-2007, 23:04
Fidgetting
I was actually worried about how to keep the tubes in alignment. I was thinking of adding some sheets to the frame that would brace between the tubes vertically. And now that you mention it that is another good reason to use four motors, there is again less precision needed. While I do need precision to attach the motor mounts, I can think of an easy way to do that.
In this case since the module turning comes down through the top I can't run the wires through the bearing. I would run the wires up the inside of the module and then leave a large loop of wire to allow for turning before attaching directly above the module. I would also limit the turning of the module to keep the wire from tangling.
Unread 01-05-2007, 20:29
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Alex,
We used an "Magnetic Rotary Absolute Encoder" on each wheel. They act like potentiometers, since they are connected to an analog input and are read as a value between 0-1023. However, they do not have stops like potentiometers and can be rotated freely. Therefore, they have the resolution of a one-turn pot but can be used in multi-turn applications.
We used this little piece of code to keep track of rotations:
Code:
char encoder_turns(int pot, int last, int window) {
    if(pot - last > 1023 - window)
        return -1;
    else if(last - pot > 1023 - window)
        return 1;
    return 0;
Since a value read from the encoder will always refer to the same physical position, we didn't have to worry about loosing positions after turning off the robot. However, since we had the encoder connected to the main (rotating) shaft using two plastic sprockets, we lost calibration there since the sprocket would sometimes "ride on a chain" or skip a few teeth on fast movement. It wasn't a major problem, since we recalibrated before every round.
We then used 2 PI loops on each module (cw,ccw) to get it in the position we wanted. I could write a whole essay on control theory right here, but I think Jimmy's post "sums" it up: http://www.chiefdelphi.com/forums/sh...int#post617897
We also ran the wires upwards through a central shaft. We made them long enough to allow for about 3 rotation each way. We kept track of the turn count in programming and saved it to the eeprom so that we wouldn't loose track. We also wrote an unspin function that unspins the wires.
Unread 01-05-2007, 21:44
DonRotolo's Avatar
Back to humble
FRC #0832
Seems to me that window lift motors - or a similar worm drive system - might be better for the steering motors. They rotate slowly - but maybe not slow enough - and have significant torque, and take the bumps pretty well. Plus, they are available cheap in surplus and reasonable in new.
Some newer types sometimes have integrated quadrature sensors (used for detecting objects during auto-close of the windows) that are sensitive and can be used to maintain steering alignment (along with a 'home' switch for recalibration).
Some idle thought, is all.
Don
Standard vs. Custom Frame brennerator Technical Discussion 62 23-12-2006 22:54
Standard Joysticks EricWilliams Programming 26 01-04-2006 22:59
Standard Servos? Matt Krass FIRST Tech Challenge 4 22-11-2005 08:09
Developing a standard Jack Scouting 23 03-01-2003 23:04
