Go to Post Isnt it fun submitting your mentors behind their backs for the WFA? - Lil' Lavery [more]
Unread 30-04-2007, 21:54
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is online now
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Re: pic: A more standard aproach
Just out of curiousity, how do you keep the wires on the drive motors from tangeling around the sverve module?
Unread 30-04-2007, 22:24
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
We limit the travel to only one rotation plus a few degrees, max. This year we closed that down even further. The wiring comes right up out of the top of the module and the upper bearing point is a hollow tube which the wires run through.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 30-04-2007, 23:04
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
I was actually worried about how to keep the tubes in alignment. I was thinking of adding some sheets to the frame that would brace between the tubes vertically. And now that you mention it that is another good reason to use four motors, there is again less precision needed. While I do need precision to attach the motor mounts, I can think of an easy way to do that.
In this case since the module turning comes down through the top I can't run the wires through the bearing. I would run the wires up the inside of the module and then leave a large loop of wire to allow for turning before attaching directly above the module. I would also limit the turning of the module to keep the wire from tangling.
Unread 01-05-2007, 20:29
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Alex,
One thought I had after my intitial post is the problem of keeping the steering motors in alignment. It is an issue using two motors and chain for us. To keep all four tracking is going to take some processing power and sensors.
We used an "Magnetic Rotary Absolute Encoder" on each wheel. They act like potentiometers, since they are connected to an analog input and are read as a value between 0-1023. However, they do not have stops like potentiometers and can be rotated freely. Therefore, they have the resolution of a one-turn pot but can be used in multi-turn applications.
We used this little piece of code to keep track of rotations:
Code:
char encoder_turns(int pot, int last, int window) {
    if(pot - last > 1023 - window)
        return -1;
    else if(last - pot > 1023 - window)
        return 1;
    return 0;
Since a value read from the encoder will always refer to the same physical position, we didn't have to worry about loosing positions after turning off the robot. However, since we had the encoder connected to the main (rotating) shaft using two plastic sprockets, we lost calibration there since the sprocket would sometimes "ride on a chain" or skip a few teeth on fast movement. It wasn't a major problem, since we recalibrated before every round.
We then used 2 PI loops on each module (cw,ccw) to get it in the position we wanted. I could write a whole essay on control theory right here, but I think Jimmy's post "sums" it up: http://www.chiefdelphi.com/forums/sh...int#post617897
We also ran the wires upwards through a central shaft. We made them long enough to allow for about 3 rotation each way. We kept track of the turn count in programming and saved it to the eeprom so that we wouldn't loose track. We also wrote an unspin function that unspins the wires.
Unread 01-05-2007, 21:44
DonRotolo's Avatar
Back to humble
FRC #0832
Seems to me that window lift motors - or a similar worm drive system - might be better for the steering motors. They rotate slowly - but maybe not slow enough - and have significant torque, and take the bumps pretty well. Plus, they are available cheap in surplus and reasonable in new.
Some newer types sometimes have integrated quadrature sensors (used for detecting objects during auto-close of the windows) that are sensitive and can be used to maintain steering alignment (along with a 'home' switch for recalibration).
Some idle thought, is all.
Don
Standard vs. Custom Frame brennerator Technical Discussion 62 23-12-2006 22:54
Standard Joysticks EricWilliams Programming 26 01-04-2006 22:59
Standard Servos? Matt Krass FIRST Tech Challenge 4 22-11-2005 08:09
Developing a standard Jack Scouting 23 03-01-2003 23:04
