Go to Post But no matter how you place, the thing to watch for is the character change in the team members. The trophies are only important for a few hours. The character that is built will last a lifetime. - BrothersKeepers [more]
Unread 10-05-2007, 11:08
Lenyaw's Avatar
Lenyaw Lenyaw is offline
AKA: Wayne Lamon
FRC #1293 (D5 Robotics)
Lenyaw is an unknown quantity at this point
Re: pic: 1293's drive system
Originally Posted by Rex114 View Post
Treadmill-bot? Is it a completely flat bottom surface on the tracks? How well did it turn?
Any pictures of the arm? Is it made out of diamond plate? Seems like a heavy material choice for an arm. Is it jointed or does it telescope? I see a window motor in the bottom left hand corner, maybe for a wire spool?
Sorry, lots of questions, looks like a very unique design, I can see why they wanted you to wait.
Mike C.
Mike
Here are slightly better pictures showing arm, gripper & better shot of treads.
The tower was diamond plated aluminum, with all the water jet cut outs, it was very light, 3-4lbs if I remember right. The center circle of each x on the sides are the 3 schools logos that make up D5 Robotics.
Gabe
If you haven't already viewed the videos, yes they are individual plastic links with 2 rubber tread grips on each link. Way too much traction! No one was able to move us an inch sideways, even on the hardest hits. Even if code errors were fixed and grinding off every other rubber grip, we still would have had slight difficulty with traction in turns. The slickest feature was two bolts removed the entire track assembly on each side for super quick repairs.
Wait until next years secret design. Can you say "Omni-treads" Opps, too much info!!!
"Learn from the mistakes of others, we won't live long enough to make all of them for ourselves"
Unread 10-05-2007, 12:13
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Did you buy these treads or manufacture them yourselves? If you bought em... where? I want some!
-q
Electrical Engineer Illini
Unread 10-05-2007, 20:17
Billfred's Avatar
Billfred Billfred is offline
I remember it being a product called uni chain. 1293's had it sitting in their shop since 2005, and it also saw use on Chomp's shooter wheels last year. It's pretty awesome stuff in the right hands.
Unread 11-05-2007, 07:24
AKA: Alex
Thanks! Should be a nice change from the BrecoFlex stuff we've been using since 2002/3.
-q
Unread 11-05-2007, 08:31
team1203 4life's Avatar
team1203 4life team1203 4life is offline
President
FRC #1203 (Pandemonium)
team1203 4life is a jewel in the roughteam1203 4life is a jewel in the roughteam1203 4life is a jewel in the rough
Send a message via AIM to team1203 4life
nice drive syestem man how did you put that together my team wants to do a tank drive if you have any hints please do tell
Unread 11-05-2007, 09:47
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Looks like a pretty serious drivetrain!
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 14-05-2007, 09:18
Lenyaw's Avatar
AKA: Wayne Lamon
Here is the breakdown of our track modules.
On the front side, the sprocket was mounted to two CIMs via a banebot gearbox. On the back, the green radius was fitted into large slots & spring loaded for track tension. The 2 small square holes were fitted to our 80/20 frame, which slid all the way through to the orange plate & was held with one bolt each. Extremely robust but slightly on the heavy side at around 11 lbs each (if I remember correctly).
Unread 15-05-2007, 20:21
VanMan's Avatar
VanMan VanMan is offline
NCSU student
AKA: David VanLeeuwen
no team (Team Awkward Turtle)
VanMan will become famous soon enough
Send a message via AIM to VanMan
Did it climb ramps?
2010-present - NC State University Underwater Robotics Team
ncsurobotics.com
2007-2009 - FRC 2108
2006 - FRC 926
Unread 14-12-2007, 12:14
Sairamluap Sairamluap is offline
AKA: Paul Marias
FRC #2192 (DAC Attack)
Sairamluap is an unknown quantity at this point
how pricey were they?
Unread 15-01-2010, 17:17
peter1626 peter1626 is offline
FRC #1626 (Falcon Robotics)
peter1626 is an unknown quantity at this point
what kind of material did you use for the treads themselves and what is the green material in the middle?
Unread 14-01-2012, 13:30
Free Willy's Avatar
Free Willy Free Willy is offline
Free Willy is an unknown quantity at this point
I know this is from a while ago, but are there any other pictures of this design? We would love to know more about it, especially how the inside of it worked.
pic: 612 Drive System Priyadarshy Extra Discussion 13 31-01-2007 18:09
pic: 612 New Drive System Priyadarshy Extra Discussion 4 20-01-2007 23:21
pic: rookie drive system psycho7 Robot Showcase 13 13-03-2006 10:29
pic: SimSwerve Omnidirectional Drive System CD47-Bot Robot Showcase 6 12-06-2004 14:09
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
