Thread Tools |
Rating:
Display Modes |
Re: pic: 1293's drive system
Thanks! Should be a nice change from the BrecoFlex stuff we've been using since 2002/3.
-q |
nice drive syestem man how did you put that together my team wants to do a tank drive if you have any hints please do tell
Looks like a pretty serious drivetrain!
On the front side, the sprocket was mounted to two CIMs via a banebot gearbox. On the back, the green radius was fitted into large slots & spring loaded for track tension. The 2 small square holes were fitted to our 80/20 frame, which slid all the way through to the orange plate & was held with one bolt each. Extremely robust but slightly on the heavy side at around 11 lbs each (if I remember correctly). ![]() |
Did it climb ramps?
what kind of material did you use for the treads themselves and what is the green material in the middle?
I know this is from a while ago, but are there any other pictures of this design? We would love to know more about it, especially how the inside of it worked.
| pic: 612 Drive System | Priyadarshy | Extra Discussion | 13 | 31-01-2007 18:09 |
| pic: 612 New Drive System | Priyadarshy | Extra Discussion | 4 | 20-01-2007 23:21 |
| pic: rookie drive system | psycho7 | Robot Showcase | 13 | 13-03-2006 10:29 |
| pic: SimSwerve Omnidirectional Drive System | CD47-Bot | Robot Showcase | 6 | 12-06-2004 14:09 |
| pic: Drive System | CD47-Bot | Robot Showcase | 3 | 27-02-2003 14:11 |
