Go to Post FIRST is like a big roller coaster, that can only be experianced if one takes a ride which can become a liftime experiance. - activemx [more]
Unread 05-14-2007, 05:12 PM
pic: VEX Mecanum Concept Wheel
Unread 05-14-2007, 05:15 PM
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: VEX Mecanum Concept Wheel
Shown on the right, the mecanum wheel is made of parts from vexlabs.com. The non-competition-legal parts are the white 1/2" nylon spacers.
Actually, as shown that mecanum wheel is FVC legal. VexLabs sells 1/2" nylon spacers (link) and by using a file and a poorman's lathe (aka drill ) you can file the curve into them.
Art Dutra IV
世上无难事,只怕有心人.
Unread 05-14-2007, 05:36 PM
I was under the impression that if it did not come specifically in the VEX starter kit then it is not competition legal?
GitHub
Unread 05-14-2007, 05:41 PM
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
mostly everything from vexlabs is completely legal for competition unless it says that it is not on the website or in the rules
Shawn Burgen-FRC Team 839 Mentor
Team 839 FTC Mentor
Unread 05-14-2007, 05:47 PM
Well that's nice to know. Even though it's part of a spacer "set" it's still cheaper to get them through vexlabs than home depot, lowes, Ace, Target, or Walmart. They're also softer, easier to file, and get better traction than those at the places above.
GitHub
Unread 05-14-2007, 05:48 PM
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
methinks you will have a really long (if not hard) time making 64 perfect rollers (2 per roller, 8 rollers per wheel, 4 wheels on the bot).
vivek
Unread 05-14-2007, 05:51 PM
vivek
the local college by us has a CNC lathe that would be able to make 64 perfect rollers.... That would be awesome.
By hand would be much harder. Is that how you made them?
When can we expect to see a working chassis?
Unread 05-14-2007, 05:52 PM
aka Shawn Burgen
vivek
when i made my vex meccanum wheels those were the most time consuming part by drilling them out and to assemble them
Team 839 FTC Mentor
Unread 05-14-2007, 06:16 PM
Yes, I used a variable-speed drill and a file that has 4 different surfaces to file them down. They're not perfect, but to file 10 of them it took ~45 minutes.
To drill through the metal pieces it took 10 minutes since I came up with a way to do them all at once.
I bent the metal by hand so it's not exactly 45 degree, and the spacing on the rollers isn't exact either. It's a concept though, to show that it can be done.
GitHub
Unread 05-14-2007, 06:21 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Another Vex Mecanum Wheel:
http://www.chiefdelphi.com/media/photos/25957
Unread 05-14-2007, 06:23 PM
If you have access to machine tools you can probably make a dye (or is it die?) out of steel so you can bend them all exactly 45.
Unread 05-15-2007, 05:53 PM
Unfortunately, IFI will not break up the $8 kit that comprises of the plastic (and adjustable) lock bars. To complete a single set of wheels with this design, one would have to spend $48 for these parts alone. Before those, the price per wheel would be $14 per wheel with 8 rollers.
GitHub
Unread 05-15-2007, 06:01 PM
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Why can't you just buy the same nylon spacers at your local hardware store? Would then only cost about $32... depending on how much each one costs. Some stores vary, the one I work at has them around $0.35 each... I can get them at about a dime a piece or less after discount.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 05-15-2007, 06:16 PM
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Well since many people are showing their vex mecanums, I might as well show what I am up to...
The wheels are roughly the same size as the 4" wheels. Uses eight 2" lengths of vex shaft and 16 shaft collars per wheel.
I hope to have these wheels done soon.
Unread 05-15-2007, 09:07 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
He is referring to the "lock bars" that make the wheel spin with the axle, not the spacers.
Kit ($8):
http://www.vexlabs.com/vex-robotics-...it-parts.shtml
pic: 1683 Concept 8 Wheel Drive sdcantrell56 Extra Discussion 16 04-16-2007 02:22 PM
pic: 114 wheel concept....again. CraigHickman Extra Discussion 5 10-21-2006 02:53 PM
pic: 114 wheel concept CraigHickman Technical Discussion 8 06-22-2006 02:24 PM
pic: 2" Mecanum Wheel Tytus Gerrish Technical Discussion 17 04-22-2006 12:22 PM
pic: Micro Mecanum wheel Tytus Gerrish Extra Discussion 6 05-12-2005 11:20 PM
