Go to Post The world is run by those that show up... - AdamHeard [more]
Unread 15-05-2007, 16:16
David55 David55 is offline
AKA: David Hillman
FRC #1577 (Steampunk) & FRC #125 (NUTRONS)
David55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to behold
Re: pic: Differential Swerve (Close Up View) with Advanced Gear Kit
Originally Posted by Lil' Lavery View Post
Is the differential the only thing that comes in the "Advanced gear kit"? Does it come as one unit, or does it have to be assembled? I assume the bevel gears could be used for other applications?
The kit comes with the differential frame, bevel gears (which can be used in the differential or for other applications), rack gears and worm gears (plus a few spur gears to use with the worm and rack gears).
You can see the contents here: http://www.vexlabs.com/vex-robotics-...gear-kit.shtml
pic: A Better View of Racky With All Cylinders in Stowed Position DanDon Robot Showcase 2 20-02-2007 21:06
Help with the Kit Gear Tooth sensors Keo-san Programming 9 20-02-2007 08:07
pic: GEAR BOX with two speed ericwittlich Extra Discussion 6 19-07-2005 22:01
Need help programming our swerve with feedback? activemx Programming 25 13-04-2004 07:29
Close Encounters with Team 48 SwordSerenity Chit-Chat 7 13-02-2003 12:26
