Go to Post ask not what your alliance picks can do for you, but what you can do for your alliance picks. - Swan217 [more]
Go Back   Chief Delphi > Technical > Control System
Unread 17-05-2007, 01:17
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: pic: 2007 Robot Brain
The Cat Plate
Originally Posted by Kris Verdeyen View Post
Originally Posted by cbale2000 View Post
I'll bet the judges gave you a hard time about it. I'm amazed you didn't have any issues with overheating. I know had we put that many victors so close together our mentors would have made us use additional fans!
Just out of curiosity, why did you make it so small? Did you need space or just felt like keeping it compact?
I was in charge of inspecting the robot this year again and the inspectors loved that the brain was very organized and that is all they liked , they had some issues with our brain being mounted on top of our fuse panel (20A-30A) but after a flashlight and a screwdriver they lightened up, but insisted SEVERAL times to make everything more visible in the future.
Our reason for making it so small is because of our base. If you see pictures of our robot, we have a very low CG and we had planned the base to place certain key components in certain spots (the V6, Compressor, Battery, Brain). So to answer your question, we space elsewhere on the robot for other functions AND we wanted to make it compact after previous years of our "keep it together" strategy.
Originally Posted by Stephi Rae View Post
Very impressive. I would also like to see that modeled in inventor. we're a rookie team, and i had to come up with our electronics organization this year and used inventor to lay it out... unfortunately we had to do a lot of rearranging... I think that if I were able to compact things like this we would have a lot less trouble next year. If I am seeing things correctly your RC is elevated, right? therefore giving you space to work with underneath, where you keep your backup battery I assume? as well as maybe a spike or two it appears, and a few pwms run under there... right? haha maybe i'm assuming too much, that sounds like a lot of stuff under there, but i guess I wouldn't doubt it seeing how much you fit in the area surrounding the RC.
Yes sir you are correct, our RC is mounted higher but you are mistaken as to what is under there. Underneath lies our 20A-30A fuse panel. Also on our RC you might notice a piece of Velcro, that is where our backup battery was placed during competition.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 17-05-2007, 05:21
CWBWBN's Avatar
CWBWBN CWBWBN is offline
www.boredom-induced.com
AKA: Marcus
FRC #0179 (Swampthing)
CWBWBN is a glorious beacon of lightCWBWBN is a glorious beacon of lightCWBWBN is a glorious beacon of lightCWBWBN is a glorious beacon of lightCWBWBN is a glorious beacon of lightCWBWBN is a glorious beacon of light
Send a message via AIM to CWBWBN Send a message via MSN to CWBWBN Send a message via Yahoo to CWBWBN
that is definately the cleanest electronics board i have ever seen for as much stuff is on there!!
mch
<3
pic: MVRT115 2007 Robot Ashwin Robot Showcase 11 23-02-2007 14:00
pic: 662's 2007 Robot NK2007 Robot Showcase 2 10-02-2007 20:38
pic: FRC488 2007 Robot Madison Extra Discussion 17 04-02-2007 01:56
pic: 610 Teaser, A Coyote's brain??? Jonathan Norris Extra Discussion 5 29-01-2007 11:04
pic: Your brain on FIRST Elgin Clock Extra Discussion 11 20-04-2006 21:59
