#16
Re: pic: Vex Mecanum Wheel
as he said, they do work well, our only problem was getting the 4 motors to run the same speed. you might have seen us playing with it in the pit in Atlanta if you were in Curie, while our robot was out at a match.
EDIT: Also, you don't want to know how many brackets were broken trying to clean them from the rapid prototyper's "build-up" stuff. They used to be pretty flimsy. >_> |
#17
I agree. The first wheel I made took ~8 hours since I was trying to get it right. I created the other 3 about 3 hours, 2 of which were drilling/filing. After you figure the first one out it's pretty easy to figure out how to mass-produce them.
Very worth the effort to figure a problem out when it has substantial gain. It even took less time than a 3-D printer takes to "print" a design you give it ![]() |
#19
Can you send me a drawing mecanum wheel?
Thank you very much |
#20
Welcome to CD! Great job trying the search, but try to check the thread age. |
| pic: VEX Mecanum Concept Wheel | JesseK | Extra Discussion | 18 | 17-05-2007 10:27 |
| pic: Mecanum Wheel Project - Rev. D | Madison | Technical Discussion | 17 | 07-08-2006 18:19 |
| pic: Mecanum Wheel Project - Rev. E | Madison | Technical Discussion | 8 | 13-07-2006 13:31 |
| pic: 2" Mecanum Wheel | Tytus Gerrish | Technical Discussion | 17 | 22-04-2006 12:22 |
| pic: Micro Mecanum wheel | Tytus Gerrish | Extra Discussion | 6 | 12-05-2005 23:20 |
