Go to Post unless your team is incredibly beastly, completely ignore the words "cool factor". Coolness does not outweigh functionality. - Sam N. [more]
Unread 23-05-2007, 17:54
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Excellent paper!
Originally Posted by tseres View Post
ahhhhh...after looking at a lot of other things....
so i guess PID is basically having software control the robot rather than just the PWM outputs are the same as the joystick values...so there's a layer of software that processes all the input and output data.
Exactly. Programming this way makes you paranoid--you start to trust the code, have a sensor go bad on you, the arm takes off and tries to rip the control system off the robot while destroying a gear box (BaneBots... ) and you don't hit the disable switch fast enough. (true story, times about 50 this season )
But don't let that steer you away from a smarter robot. The pros greatly outweigh the cons. For example, auton becomes easy.
Good luck,
Jbot
Aren't signatures a bit outdated?
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
White Paper Discuss: An Introduction to C Programming for First Robotics Applications CD47-Bot Extra Discussion 10 26-11-2004 21:54
White Paper Discuss: Official 2004 Introduction to Programming Guide CD47-Bot Extra Discussion 4 26-01-2004 20:59
control system programming archiver 2000 17 23-06-2002 22:14
Where can i Find info on the control programming Matchew General Forum 1 14-01-2002 19:09
