Go to Post Just fill your wheels with depleted uranium - EmileH [more]
Unread 02-06-2007, 01:12
Smaug's Avatar
Smaug Smaug is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Electrical
Smaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the rough
Re: pic: Pneumatic
what kind of air motors are those and are the cheep?
my friend and i want to experiment with those before build season
If it isn't broken, Fix it till it is ~ Baker
Unread 02-06-2007, 01:24
Nuttyman54's Avatar
Mentor, Tactician
AKA: Evan "Numbers" Morrison
Re: pic: Pneumatic
I cant' help but notice how little chain wrap you have on the drive sprockets. did you experience much chain slippage?
Unread 02-06-2007, 10:49
K.Porter's Avatar
K.Porter K.Porter is offline
Not So Random!
FRC #0172 (FALGOR)
K.Porter will become famous soon enough
Send a message via AIM to K.Porter Send a message via MSN to K.Porter
Re: pic: Pneumatic
Actually, chain slippage was one problem that I didn't have with the chains.
If you notice the front axle's connection to the frame in that picture, I've milled some simple slots for the bolts as a basic chain tensioning system. I just pulled the chain taught with the whole axle assembly before tightening the bolts. That tension kept everything pretty well in place.
One problem I did have with the chain, though, was that the added tension would attempt to pull the wheels slightly out of line with each other (there's a little bit of slop between the wheels and axle, allowing that movement) Occasionally this will get to the point where the chain will jam slightly on the wheel sprockets, but it's a minor problem.
As for the air motors, I found them in the back room of my school's technology classroom. The only information printed on them is "Gast Mfg. Corp." but looking at their website, the exact model seems to be out of production. As for cost, I really have no idea. Gast doesn't even list anything on their website for current models...
Unread 02-06-2007, 15:20
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Re: pic: Pneumatic
Checked on McMaster... the prices range from $135 (team numbers in everyday places ) to $972 .
One major major advantage to these motors is that in a low torque application requiring super high rpm such as engraving or micro-machining, these things rock... the cheapest air motor has a top speed of 10,000 rpm at 90psi, 18cfm... we used these at the place I work to do some engraving 1/32" ceramic end mills.
Well... I have a question about your robot too... how fast did it go? did you have variable speed? was it reversable? if you had variable speed, how'd you do it?
-q
Electrical Engineer Illini
Unread 02-06-2007, 22:43
K.Porter's Avatar
Not So Random!
FRC #0172 (FALGOR)
Re: pic: Pneumatic
How fast did it go: Well, I don't have a number for you (sorry) but: pretty darn fast, at least relative to the other vehicles it competed against. It could cover the 3 feet to the end of the table in under a second.
As for variable speed...yes and no. We basically used the main air valve for control (turn one way, go faster, turn the other slow down. Primitive yes, but it works.)
And, in theory it was reversible. Since I ran out of time to work on it, I couldn't finish my solenoid control box. I was planning on running a tether line to each of the four motor inputs (you can see the two un-used tubes in the picture) and then using the solenoids to reverse the flow to either motor, in order to turn or reverse. I prototyped the concept, but simply didn't build the control unit...
Unread 05-06-2007, 09:59
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Re: pic: Pneumatic
Looks nice, how did it do?
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
pic: pneumatic actuation of ball valve Andrew Schuetze Extra Discussion 2 30-10-2006 08:40
pic: 830 teaser # 3 Pneumatic Pistons Karthik1 Extra Discussion 12 12-04-2005 20:05
pic: Pneumatic system |_-LuIz-_| Robot Showcase 1 02-03-2005 21:31
pic: Now thats a silly place for a Pneumatic Ianworld Extra Discussion 3 30-01-2005 17:26
pic: My Pneumatic Bandana Launcher CD47-Bot Extra Discussion 8 04-03-2003 13:02
