Go to Post "By three ways we may learn wisdom: first is by reflection, which is noblest; second by imitation, which is easiest; and third by experience , which is the bitterest." - bEdhEd [more]
Unread 30-01-2006, 10:50
ajlapp ajlapp is offline
AKA: Anthony Lapp
pic: Team Rush 27 - unofficial teaser
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Unread 30-01-2006, 10:52
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: Team Rush 27 - unofficial teaser
I don't think it will come as a big surprise to anyone that team 27 will have a turret this year. They are the turret masters for a long time. It looks good though, i wish i had a water jet.
Greg Needel│www.robogreg.com
Unread 30-01-2006, 11:20
Jimmy Holmes Jimmy Holmes is offline
It's not all about the robots
FRC #0027 (Team Rush)
Rookie Year: 1997
Jimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of light
I thought you looked suspicious holding your shoe against the USB port on the computer last night. You must have a USB drive in it. What will Nike think of next.We will have to deal with you in our special way.
I wish I knew what that was also
The water jet work we had done was donated. They were very nice to help us out.
Actually it could be a shoe Camera... I don't know how you did it. I guess its time to beef up security.
Unread 30-01-2006, 14:33
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Speaking of turrets.
How have people designed cable routing through the turret for stuff above the rotation point?
Have you rotated so much that you have pulled cables out? That = Bad.
Just curious.
Unread 30-01-2006, 16:12
Rookie Year: 1997
We have always battled with how much rotation is to much. We have gone past 360 degrees in the past and had software stops on it. We would have to have a lot of extra slack in the system as it would shorten with the rotation. We also found it would get confusing at times where you were in the rotation. We had a button that would re-zero it if we got lost. Lets just say i wish the wires would stretch more at times.
We have tried to go with less rotation in the last few years, nothing more than 270 or so. If you are running balls through the center of the turret you will then have to run the wire around the outside which could limit you even more.
Of course you could try slip-rings. We have found them to be cost and time prohibitive but they may work for your application
Unread 30-01-2006, 23:01
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
Looks Heavy
Unread 30-01-2006, 23:03
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Looks veeery familiar....
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 31-01-2006, 00:18
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
i really can't seem to figure out why those two pieces are meshed. And I sure hope you can hold more than 5 balls.
Unread 31-01-2006, 10:24
Rookie Year: 1997
I don't remember what the weight is but its within the guidelines set for each Sub-team.
The ball elevator is just that, a way for the ball to get to the other device. We may have something else that feeds that.
They are coupled together so that the elevator transfers the ball thru the center of the turret.
Unread 14-02-2006, 17:54
want2modmygt's Avatar
want2modmygt want2modmygt is offline
AKA: Will
#0494 (Team RUSH 27 (2 years) -----> Goodrich Martians)
Team Role: Electrical
want2modmygt is on a distinguished road
looks good! i love the water jetting. i can't wait to see it on the chassis. a little off topic, but where are you guys building? is that in Mrs. Hughes' kitchen?
www.cardomain.com/id/redbeauty2006
my 1997 GAGT
Unread 31-05-2007, 21:34
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
How did you know what shape to cut the teeth on the large gear in order for the teeth to mesh properly, and did you also custom make the gear that meshes with this large gear?
Unread 03-06-2007, 09:46
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
I can't vouch for this team, but what we've done in the past is used Inventor's gear generator and then CNC'd the drawings. The same could be done with a waterjet machine for smaller, more precise pieces. I have heard that plasma cutters are too messy to make gears, but our team doesn't have access to one.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 03-06-2007, 21:32
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
I don't want to step on anyone's toes here, but i talked to AJ a lot about this and they waterjetted the large 12 DP gear using Inventor's gear creator......then the used 12DP gear stock and mated it to the globe motor to power their turret
Different angle:
http://www.flickr.com/photos/jskowsk...7594544779400/
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
pic: Team 830 Rat Pack Teaser Jeff Waegelin Extra Discussion 24 12-02-2005 23:46
