Re: pic: Freud
I dont have the slightest idea what it is...
![]() Care to explain? |
Re: pic: Freud
I'm curious as to where the control system is mounted, on the underside?
I believe this is a very compact, low cost two wheel swerve drive. |
Re: pic: Freud
Cautiously, I ask: why is it named Freud-- or is that one of those "if you have to ask..." type of things?
Re: pic: Freud
One of my prototypes for the controls box for next year looked a bit odd because of the amount of space on a said part of the robot i was designing it for, but that did not mean I had any perverted intention what so ever, it was just that there was a limited amount of space to design this particular piece and I used as much as I could.
Re: pic: Freud
Let's leave the phallic discussion for somewhere other than this site, please.
Re: pic: Freud
Sorry for provoking it!
Re: pic: Freud
what kind of router do you have? , Alex? how did you set up your cut?
Re: pic: Freud
First, the shape wasn't intended but just because that is the case doesn't mean I can't have fun with the name
. On another note there has not yet been a person who has seen it that hasn't identified it as phallic.what is missing is two speed controllers and some type of RC. I was going to use a vex but I don't know if it can control the spike (if somebody knows it would be very helpful). I cut every piece on the machine with one of these: http://www.intelitek.com/products/pr...=1&pid=2&did=8 My school has had one for several years but nobody knew how to use it (even my teacher). I spent the last couple of school years teaching myself to use it and I think I have done pretty well so far. The cut was set up using a piece of plywood that was several inches too large so that I didn't need to be accurate. I hope that answers your question. I had to do a little tweaking of the battery hole because it was a little small but other than that it has been working perfectly. Thanks for all the comments. Alex Last edited by Alex.Norton : 04-06-2007 at 01:53. |
Re: pic: Freud
i don't think it is done as of yet, because the main wires are not in there ( wires coming from the battery). I think he is going to add a second layer with the RC
