Go to Post The folks in Indiana don't play around. - PayneTrain [more]
Unread 04-06-2007, 08:58
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: pint sized chaos v2
Originally Posted by Greg Peshek View Post
The Super Heavies are super in most ways, meaning super expensive as well, thus being why there are not many built. There is also less of them competing than the Featherweight class this is being built for. For RoboGames '07 there are 29 Featherweights registered while there are only 7 Super Heavies (http://buildersdb.com/view_bots.asp?eventid=196).
The wedge fed design is meant to feed the other robot into the blade, the blade will hit the other robot (hopefully) from underneath and will send it skyward, of course the disadvantage is if the opponent has a lower wedge then you can't get any hits with the blade which is why wedge fed blades are generally only fed one way and have the blade sticking out the other side so they can wedge feed the blade and use it normally.
-Greg (Not the one posting the CAD, if you were temporarily confused)
Exactly. one of the downfalls of having an exposed blade is that taking a side hit on it can do major damage. We felt that even with the possibility of not getting hits with the weapon we could do fine in the chance that their wedge was lower. After competing at one competition the biggest issue was that our lowest wedge (we called it the skirt) would get damaged and then it would be impossible to wedge anyway. Typically I build combat robots for one event, but I think I might re-build this one. If I do I will be removing one of the wedges making it one sided, and also putting a more powerful motor on the blade.
Greg Needel│www.robogreg.com
pic: Chaos Over the Ramp BandChick Extra Discussion 2 21-05-2006 20:43
Speaking of life-sized games.. Adam Shapiro Chit-Chat 5 14-05-2006 12:37
pic: Travel sized-ness Lisa Perez Extra Discussion 5 24-04-2005 23:08
pic: CD on a Super Sized monitor. Elgin Clock Extra Discussion 14 13-04-2005 01:48
pic: CHAOS 131 CD47-Bot Robot Showcase 12 01-03-2003 23:53
