Go to Post FIRST cannot enforce Gracious Professionalism on the participants in this program, you will have to do it on your own. - Ken Leung [more]
Unread 08-06-2007, 09:00
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: pic: 648 Cardboard Crab Steer Boat 1
By the way, does anyone know if and how you can set custom densities in Inventor? If anyone knows, I'll post the estimated weight of the boat.
Create a new material using the Styles Editor:
-Select "Default", or whatever is closest to cardboard.
-Click "New", and type in a name for the new material ("Cardboard").
-Enter the mass properties and click Save.
-You can also edit which texture the material uses by default, as well as other physical properties.
-You'll have to import the Cardboard material into each part. I'm not sure how to do this with Inventor 11.
-Set the part(s) to be cardboard.
Hope this helps!
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
The Great Cardboard Boat Regatta SgtMillhouse648 General Forum 11 06-06-2007 14:54
CardBoard Rollercoaster Chaos204 Math and Science 6 29-12-2006 20:10
Dual wheel per axle set crab-steer concept Andrew Schuetze Technical Discussion 8 21-06-2006 08:55
pic: 648 Shooter Jeremiah Johnson Robot Showcase 1 03-03-2006 01:07
pic: Team 648 Is Now Here CD47-Bot Robot Showcase 7 12-02-2004 09:12
