Go to Post Dee and I pooling our brain cells almost make a full deck... - RoboMom [more]
Unread 21-06-2007, 20:57
s_forbes's Avatar
anonymous internet person
FRC #0842 (Falcon Robotics)
pic: 1726 Demo Bot
Unread 21-06-2007, 20:58
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: pic: 1726 Demo Bot
this is a way better rubber band firing mechanism
http://www.mocpages.com/moc.php/22386
Unread 21-06-2007, 21:24
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
pretty cool does it fire at the green target?
Unread 22-06-2007, 17:08
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
pretty nice.
are all 6 wheels powered?
how many drive motors?
Unread 22-06-2007, 19:09
s_forbes's Avatar
4 motor, all wheel drive, 1:1 ratio. The drive base was taken from a previous vex bot made to play our summer vex camp game.
It's programed to fire after it aims itself properly at the light. (The rubber bands make a cool *plink* sound when they hit it. ) Our programmer finally got a hold of easy c, so he is having fun learning how to use it.
Unread 27-06-2007, 12:03
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
You can use the camera without connecting it to a TTL port on an RC? How do you feedback "pan" info to the Vex controller? I take it the drive platform is the camera's "pan" system. I have to admit I don't do a whole lot of camera programming, so please elaborate, I'm a bit confused.
Work Hard, Have Fun, Make a Difference!
Unread 27-06-2007, 12:56
TheOtherGuy's Avatar
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
I found out how to connect the camera to the microcontroller via this post. You basically connect the TTL port on the camera to the tx and rx ports on the vex microcontroller (which are on the same side as the ana/dig inputs). The camera does a lot of processing itself, and it returns a bunch of variables, including the pan angle for the pan servo and the center of the mass. Using EasyC Pro made getting the camera to work a breeze, all you have to do is make some unsigned characters and assign them to whatever the camera returns.
The pan system is only half of the drive system, you need the tilt to figure the disance from the object. The farther away, the lower the angle, the closer, the steeper the angle.
We got it so it'll drive arcade mode to drive up to the light, so it combines the two values and figures the value for each motor. We just made the rubber band gun fire when the robot was happy with it's position.
That's pretty much all there is to it! I found out vex doesn't work too well with the camera because the motors don't provide as much control as you want (ie adding a pid loop made the robot stop short of it's goal, and then 5 seconds later JUMP forward several inches. We never quite got it to accurately tell the distance...)
Ideas for a demo bot Jeff 801 General Forum 17 31-05-2007 09:01
pic: Vex demo bot Eldarion Extra Discussion 6 16-04-2007 16:54
Paly Robotics 2007 Bot Demo Guy Davidson Robot Showcase 2 06-03-2007 18:49
pic: 1726 2007 OI TheOtherGuy Extra Discussion 2 11-02-2007 23:17
Video of Rookie Team 1726 bot in action yodameister Robot Showcase 0 25-02-2006 02:25
