Originally Posted by dbell
The shafts that go between the 2 red plates and hold the wheels are .75:" thick. In the end of those there is a .5" threaded hole. The DeWalt will screw into the end of the shaft. Then i will drill a hole through both shafts and put a pin through. Hopefully this will be solid and strong.
3/4" diamater shafts will definately be strong enough; especially if they are steel. Depending on the size of the pin you're putting through, aluminum should be just fine. Either way, 3/4" is kind of heavy though. I guess you don't have much of a choice w/ the current interface with the dewalts though.
