Go to Post Me: Hi, Honey - I'm home! Wife: Must have shipped the robot today, huh? - meaubry [more]
Unread 09-07-2007, 19:11
Re: pic: DeWalt drive base: side module
Originally Posted by Greg Needel View Post
As an example when you are talking about strength it is obvious that you are referring to not failing during application, but in what ways is the part strong enough. Are you concerned with the torsional strength to make sure the shaft wont twist off? What about the bending stresses of this kind of loading And don't forget to take into account the stress concentrations caused by the pin slot and the fatigue strength due to alternating loading...What about the shear strength of the pin itself?
Looking at the amount of torsion put into the shaft (I just ran some similar calcs yesterday for a 1/2" shaft ) that shouldn't be the problem, What I was reffering to was that the point of failure will probably depend on the pin (either the pin itself, or the shaft where it engages the pin).
With so much time on your hands, and since you already modelled it anyway, you my as well learn to use the stress analysis built into inventor to check your it. I've been using this all season on critical parts and it has never failed me (remember to build in a safety margin).
pic: 25's drive module Billfred Extra Discussion 17 06-06-2007 10:35
pic: 114 drive module design CraigHickman Extra Discussion 3 06-12-2006 21:59
pic: Dual sprocket Dewalt drive Andy Brockway Extra Discussion 4 05-12-2006 08:05
pic: Team 710 Drive module CD47-Bot Robot Showcase 20 04-03-2004 01:21
pic: Dual-Speed Drive Module CD47-Bot Extra Discussion 3 07-11-2003 13:45
