Go to Post The code is hopefully pretty self-documenting, but I haven't had time to comment it (kinda trying to build a robot at the moment). - RyanCahoon [more]
Unread 07-15-2007, 10:14 PM
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: pic: Planetary Transmission
Originally Posted by Tapoore View Post
I like the idea, but I would never put the Denso motors in a drivetrain. Even though the worm inside the motor is metal, the gear is fairly soft plastic and strips way too easily.
If you want to make your tranny anti-backdriveable (sp?), I would recommend that using a wormgear other than the one in the Denso.
Worm gear in a drive-train also means no coasting once power to the motors is cut. Don't know if that is good or bad but seems like it would put a high load on the worm gear if a high speed run came at the end of a match...
Love the work and wish I had some ability to design drive-train transmissions.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
pic: 379's transmission Robo_Cat_379 Extra Discussion 10 03-05-2007 08:48 AM
pic: 2 Speed Transmission AustinSchuh Extra Discussion 20 12-30-2006 04:39 PM
pic: 2 speed transmission 1 psyco_klown Extra Discussion 3 09-05-2006 07:03 PM
pic: 2 speed transmission 2 psyco_klown Extra Discussion 0 05-22-2006 01:35 PM
pic: lego Planitary... Kinda CD47-Bot Extra Discussion 5 07-14-2003 11:55 PM
